Would anyone happen to know where i can get a parts type diagram for fridge freezer parts?
I have problem with my freezer where its not freezing which i think is down to the defrost coil not working and i dont know how to get the it. Its
either that or the defrost timer or defrost thermostat i think. The fridge part is cold.
Its a beko cda751f btw.
[Edited on 26/10/09 by Danozeman]
Haynes manual? Sure I've seen one for domestic appliances. Also seen one for a Spitfire and I don't mean a Triumph
Beko are made in Turkey and aren't the best for quality
Take out the shelves/baskets out of the freezer, the evaparator and controls are behind the back panel, usually held in by screws, sometimes by
plastic clips(they break).
Are you are saying that the fridge is cold but the freezer isn't? if it is frost free (no such thing, they still need defrosting at least once a
year) most likely a system fault, compressor not pumping to pressure or gas leak, never easy to diagnose faults by remote control.
lots of info on here http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35 do a search for Beko in the fridge repair
forum.
