OT: WEE controller?
tegwin - 10/11/09 at 02:09 PM
Anyone know how the wee controlers work?
I basically want to put the WEE behind the players and project over their heads onto a large screen.... Will the controlers still work? Or does the wee and TV need to be infront of the people for it to be able to work out what the controlers are doing?
blakep82 - 10/11/09 at 02:11 PM
i think they're infra red aren't they? so no. but you could run the video cable from the front to back
nib1980 - 10/11/09 at 02:11 PM
so long as the Wii motion bar is infront of them and central;ised to the image then it shouls work ok.
Humbug - 10/11/09 at 02:43 PM
Isn't that your kn*b?
mistergrumpy - 10/11/09 at 02:50 PM
Its the squeeze method isn't it?
tomprescott - 10/11/09 at 03:24 PM
Pointing system works by an infra red sensor (has a failry long lead with it) that needs to be centralised and either directly above or below the image (i.e. tv or projection). The gyroscopic functions however I believe are transmitted via rf and so should be ok to not have line-of-sight to the base unit. HTH
Davey D - 10/11/09 at 04:32 PM
the movement of a cursor on screen is done by the wiimote recieving light from 2 infra red led's in the bar you put ontop, or below your screen. the wire from the bar to your Wii is only for power. you can buy 3rd party replacements which are battery power, so no need to run a cable back to the wii.
the rest of the functions on the wiimote connect to your wii via bluetooth, so it doesnt matter where you have your console
matt_gsxr - 10/11/09 at 04:38 PM
for what it is worth they use Bluetooth to communicate. They include gyroscopes and also a little infra-red camera that sends back the position of infrared dots to the main unit.
Some interesting things on the web for making the controller do other things.
wii nerd stuff
Matt
[edit] sorry for the duplication I guess we typed at the same time!
[Edited on 10/11/09 by matt_gsxr]
contaminated - 10/11/09 at 04:44 PM
Probably discussed above, but I can't be arsed to read!
You can get a wireless sensor bar to place in front of you below the screen - so the Wii itself can go behind you.
I use a projector with mine, but I use a wireless video sender, so all the tech is in front of me except the projector itself.
The biggest problem is that to play Wii games you generally stand up - so the picture is helpfully projected on the back of your head unless you stand well back, but when you do that the signal to the sensor isn't so good!
dhutch - 10/11/09 at 06:18 PM
Yes, most of its done with g sensors and gyros. But as long as the bars infront where it should be, and the box isnt silly miles away for the bluetooth fails, game on.
Daniel
scootz - 10/11/09 at 09:05 PM
Had one the last time my back gave in. They think of everything in the Neurosurgical Ward!
Catheter Linky
blakep82 - 10/11/09 at 11:46 PM
ah, pelvic floor exercises! lol
