Sky/ LNB part 2
jacko - 31/12/09 at 05:31 PM
Hi All and a happy new year for tonight
I have just been given a new LNB but it has 4 plugs on it where the old one only has 1 plug can i use the new one ok and if so how wil i know which plug to use
http://www.locostbuilders.co.uk/viewthread.php?tid=127348
Thanks for any help
Graham
rayward - 31/12/09 at 05:36 PM
yeah should be fine, you can use any of the four
hth
Ray
franky - 31/12/09 at 05:37 PM
Yes its fine to use, it just means you have 3 spare outputs.
RichardK - 31/12/09 at 05:37 PM
Any of them mate, just seal off the ones you don't use to stop moisture getting inside the lnb.
Rich
jacko - 31/12/09 at 05:47 PM
Brilliant Thank you all Have a good NIGHT i Will
Graham
Started all ready
mangogrooveworkshop - 31/12/09 at 08:02 PM
bet you wont go out tonight and install it on the sat dish
designer - 1/1/10 at 09:48 AM
New LMB's have two outputs as normal. That is so you can record a channel you are not watching.
