As Title.
I have a Mini ITX PC that would be be great if it could run as a SatNav device.
So, can anyone recommend any Software to run on XP using a GPS module.
Martin
this may be of some use to you if you are dabbling in cartographic things
http://www.gpsvisualizer.com/map_input?form=google
Memory Map
Available from t'internet " target="_blank">http://www.memorymap.co.uk/software.htm
Thanks for the response.
Had a quick look, but does not look quite what I need first off.
Look more to emulate a car Nav system like the Tomtom's.
