and it's only an omega!!! plus they wanted £75 an hour to fit it too.... would be cheaper to hire a solicitor to do it....
The Omega probably uses a Titania sensors so they do tend to be a bit more expensive. Was that for a genuine sensor or an aftermarket part?
If you fitted these things regularly you'd probably give a high quote as well to cover the utter b***ard ones that really don't want to be
removed.
[Edited on 5/3/10 by MikeRJ]
Some Omega lambda sensors are only availble through the dealer network, the sensor would have to be changed -- usually not easy then the operation checked on a diagnostic scanner.
suzuki wanted £155 plus vat for the Mrs motor
Mazda MX5, £170 from my local factors and that was with trade discount
I'd recommend against getting a solicitor to do it. They will do a rubbish job, and will be difficult to claim the money back from!
Matt
Originally posted by goaty
suzuki wanted £155 plus vat for the Mrs motor![]()
Matt
