OT wooden boat
tegwin - 6/5/10 at 02:40 PM
Having not worked much with wood until recently, I am fascinated with it... I am toying with the idea of building a small(ish) inboard boat... something like this:
http://www.classicwoodenboatplans.com/gar_wood_speedster_miss_behave.htm
Realistically, how hard do you recon it would be to build something like that with little joinery expereince?
Any idea how much the wood for something like that would cost... a LOT i would imagine
Anyone know any plans for other similar style boats that would be suitable for use on coastal water? IE.. somewhere with some waves!)
Just look at the woodwork on this:
[Edited on 6/5/10 by tegwin]
richardlee237 - 6/5/10 at 02:48 PM
I built an 18ft inboard offshore racer a few years ago. It took 2 of us working almost every evening and weekend about 9 months.
If you read plenty of books on boatbulding and have good practical skills you should be OK.
However there are a lot of jobs which really demand 2 people
With care and attention to detail you could end up with a boat that looked like the old Gar Woods racer.
Go on go for it !!
cadebytiger - 6/5/10 at 02:49 PM
WOW - that looks amazing!
You probably need quite a bit of space for bending wood and the like.
Will be interested to see what people think!
rf900rush - 6/5/10 at 03:23 PM
Somthing I always hoped too do.
Another plans sight here
BenB - 6/5/10 at 03:26 PM
Wow. Bet it would be easy to build it accidentally asymmetrically or so it leaked like a sieve! The finish on that boat looks rather good IE difficult
Canada EH! - 6/5/10 at 03:32 PM
I live in an area called the Muskoka's it hase been the playground of the rich and famous for a hundred years or more.
Wooden boats of that type have been built here for all of that time.
Names such as Grevette, Minett, Minett Shields, Ditchburn and others.
These boats were built for families from the US and Canada who would bring plans from famous naval architecs to be built locally.
Such boats are still made and restored in the area. The boat you are looking at sels for around $100,000 Canadian , about 80,000 Pounds Sterling.
jlparsons - 6/5/10 at 04:15 PM
Me and a buddy were very keen on this idea before redundancy killed it off. Still, it's on the ten year plan!
Might be worth looking at "stitch and glue" designs, they use exopy-glass bonded and coated plywood. They tend to be a little simpler in design but they can still look the bees knees and they cut production time drastically and arguably this construction can increase durability and decrease weight.
Ivan - 6/5/10 at 05:18 PM
Go for it - the big decision is BEB or CEB - a whole new field for discussion.
Tatey - 6/5/10 at 05:30 PM
Here some free plans for a 14' canoe:
http://www.bateau2.com/free/cheapcanoe.htm
I was planning on building it before I caught the kit car bug. Once i've finished the car and got some more space I'll be setting about building it.
I worked out that it was going to cost about £150-£200 to build, which includes all of the epoxy resin required, the plywood and glass tape. They don't look too difficult to build, its not too much money if it doesn't go to plan and it wont take too long to build. So it might be a taster to make sure that you actually want to build a proper boat.
[Edited on 6/5/10 by Tatey]
Daddylonglegs - 6/5/10 at 07:49 PM
350 Chevvy would just about push that through the water
JoelP - 6/5/10 at 08:06 PM
good timing, i was plotting a catamaran in my head all day! Stitch and glue here too.
How hard can it be?! My first boat was made of chipboard and vaguely worked.
Andi - 6/5/10 at 10:02 PM
lo lo lo lo locost
Marine ply and tigerseal
Chippy - 6/5/10 at 10:03 PM
I have built several boats, three of wood, and four of GRP. The wooden ones were built from the ground up, while the GRP ones were fitting out hull and superstructure. Largest wood was 28 feet, single engine, (Perkins 40 HP), six berth, took five years to build. Largest GRP was 32 feet, single engine, (Thorneycroft 65 HP), motor sailer, took two years to build. The one thing that is required on doing any of them is dedication, and the knowledge that you won't be boating for some while. I have seen many boats started, and then never finished, and sold for a pitance once the first flush of eager beaver had gone. The second thing to know is that they always cost a lot more than you think, work out a price then double it, and you may still have to add to that. Now if that hasn't put you of, then go for it, and I wish you all the best. Fair winds and safe harbours. Cheers Ray
