How do you feed cable down a stud partition?
John P - 9/5/10 at 05:22 PM
I've got a heater mounted high on a stud partition which we want to move lower down the wall.
At present the heater is wired into a switched outlet (ie. not plugged in).and I would like to run a new cable from this outlet down to something similar at the bottom of the wall.
Since it's a stud partition it would be helpful if I could run the cable down the cavity but how do you do this. I've seen it done by electricians but never taken enough notice.
John.
mads - 9/5/10 at 05:26 PM
isn't it done using that product that woman demo'd on Dragon's Den and had them all fighting for her to go into business with her?
liam.mccaffrey - 9/5/10 at 05:27 PM
I hope I am understanding you correctly but I have drilled holes at source and destination and fed a weighted string down from the top and caught it at the bottom by using magnets/hooks.
Once you have a string you can tie off the cable and thread it through.
I have even heard of people threading cable under floor boards using rats/ferrits
[Edited on 9/5/10 by liam.mccaffrey]
BenB - 9/5/10 at 05:31 PM
It's not that tricky though if you have to go sideways or go down through any noggins it will mean cutting a square of plasterboard off, notching the noggin, feeding the cable through then putting the plasterboard back and making good.
adam1985 - 9/5/10 at 05:32 PM
Old metal coathanger sparkys normally use these
http://www.screwfix.com/search.do;jsessionid=BVUFPEEAQBJJYCSTHZOSFFY?_dyncharset=UTF-8&fh_search=Cable+rods&searchbutton.x=9&searchbutton. y=10&searchbutton=submit
[Edited on 9/5/10 by adam1985]
zilspeed - 9/5/10 at 05:37 PM
Use a bit of mini trunking to fish through. Flexible enough to move around, stiff enough to go where you point it.
Sparks use it for this job.
mangogrooveworkshop - 9/5/10 at 06:27 PM
Thats a trade secret.....dont tell the punters that
prawnabie - 9/5/10 at 06:34 PM
Magnamole?
Stuart_B - 9/5/10 at 06:40 PM
hi i just a set off these or a scrap bit off cable.
stuart
edspurrier - 9/5/10 at 07:05 PM
Ferret.
JoelP - 9/5/10 at 07:13 PM
i use a stiff bit of cable. You can use it to find the rough height of noggins, then use a 1 or 2mm drill bit to find it exactly, (ie drill in and you will feel air or wood), these holes can easily be filled. Then drill as small a hole above and below as you can get the cable threaded through, and a small channel over the stud/noggin.
If you fail, just drill as few additional holes as possible.
mad4x4 - 9/5/10 at 08:45 PM
Magnamole?
Did you watch the video - I'm sold
