always wanted to know if this would work or not
not sure how much gas there is in 2l of lemonade but at 21p a bottle must be fairly cheap way of getting CO2!
back out to garage to give it a try.... pictures to follow!
Will
my welds are bad enough without having to shake a bottle of pop with one had!
PMSL. Has to be a picture of the year on here.
dissapointing
works OK for 2 seconds, but then the pressures goes. now all i need is an automated shaker...
Will
Are soda stream canisters more or less exspensive than regular C02 bottles
surely your wallet can stretch to a £10 cannister from Halfrauds!
what about if you breathe through the co2 hose?
Do you ever watch myth busters? Mentos in a bottle of coke, or a load of Antacid tablets in water should do the trick
Originally posted by Davey D
Do you ever watch myth busters? Mentos in a bottle of coke, or a load of Antacid tablets in water should do the trick![]()
I can get dry ice from the lab - that should do the trick
Originally posted by cadebytiger
I can get dry ice from the lab - that should do the trick![]()
Put the bottle on the rocker cover of your engine. Remove one spark plug and start it up. The vibration and heat should do a good job of getting the CO2 out of the lemonade.
surely your wallet can stretch to a £10 cannister from Halfrauds!![]()
And the lemonade tastes flat after! idle hands are the devils workshop.
If you're worried about flat lemonade, you could always buy some CO2 and recarbonate it.
Cheapskate savers Lemonade
should of used schweppes you amateur !
He's a secret lemonade welder......
could last quite a while with a regulator on there actually
Why all the effort for poor quality or dubious welds.
You are going to drive this car on the public roads. You are possibly putting your life and others at risk by not doing your welding correctly.
How much are you really going to save?
Is it really worth the saving considering the potential safety aspect?
Whilst it might be fun to try it as an experiment. I Know I would never risk it on a motor vehicle of any kind.
If a job is worth doing... Then do it properly.
Sorry DJ but the lemonade idea is rubbish.
What you need is a rising bell collector over a vat of home brew.
Your welds will be crap but after a few pints of the "by-product" you won't care.
Paul G
Originally posted by 907
Sorry DJ but the lemonade idea is rubbish.![]()
Paul G
