Not a happy bunny.
I'm getting my boiler replaced and relocated + whilst there is a spark in a couple of sockets added.
Got a QUOTE from a few companies and went with not the cheapest but the one with a decent reputation and qualified to install the boiler i'm
going for (And therefore i get a 5 year warranty).
Paid the deposit and agreed an install date. Week later the electrician calls, he'd like to view the site. Comes in and says - you need a new
fuse board, its an extra 160 to bodge it or 330 for a new fuse board.
Errrm........... I've got a QUOTE, not an estimate.
Surely the gas company have to cough up and pay this after they gave me a quote and i paid the deposit.
Yes. A quote is a quote- they can't know change it. Although it does depend what they quote you for. Have you got it in writing. It might well
have a wiggle room clause.
It's for reasons like this that when you ask someone for a quote you really need to specify (to the last details) what you expect so they
don't try and wiggle out of it.
yep, a quote is definite. If it was an estimate they can change it.
ignore rant .......
despite asking for a quote, despite being told i was getting a quote, on the bottom of the letter, beneath the company address and VAT number there is
the line,
"this estimate is valid for 30 days from the date given" ........
GITS! why can't you trust anyone these days
When you are getting any type of home repair and are dealing with a contractor it is very important to set the rules down. One of those rules is that
they provide a written estimate on the work that you are having done.
You want this for many reasons, an estimate has a spot on the bottom of it authorizing the company to go ahead and do the work. This is now a contract
and both parties have to abide by it. Basically, the contractor has to complete the work that is estimated but they have to do it within the estimate.
If a contractor gives a home-owner an estimate of say an estimate of £ 2000 for a window replacement and when the job is complete the final actual
cost of the window replacement comes to £ 2800. Now the home-owner is upset and refuses to pay the installer because they went above and beyond what
the estimate said.
Which in any normal circumstance is ok, only if they have put the additional costs in writing and made sure that the home-owner sees it and agrees to
it. That way a situation like this won’t happen.
ah, the old, new consumer unit ploy !!
Ask him for a price breakdown.
The consumer unit shoud be around 100 quid plus labour. If it takes him more than 2 hours to change he is extracting the liquid waste product.
OK, he gave you an estimate not a quote BUT you shouldn't have to look at the small print burried at the bottom to know whether it's
a quote or an estimate!
Either way you may have to get the board changed but his business ethics are a bit questionable (as said above that old "quote or estimate"
chestnut)
I can't see why you would need a new 'fuse board' for the alterations you're planning. Ask why it is needed.
If it's because your existing one has no RCD protection, you could add this just for the new alterations (possibly the cheaper 'bodge'
option he suggetss) but really it's in your own best interests to have the CU replaced anyway imho.
Only a cowboy would get a CU swap done in 2 hours as richardlee237 suggests by not bothering to properly test existing circuits beforehand. If there
are any problems with existing circuits you'll then be left with nuisance tripping RCDs and face having to pay for his fault finding. Proper
spark should test existing before installing a new CU with RCDs to identify any potential problems before you waste your money. £330 is cheap for a
proper CU swap with testing - but do make sure it will be a proper CU swap. Make sure the spark is registered with a scheme (eg niceic) and that you
will get your installation certificate and that building control will be notified of the work through his scheme.
Liam
Ditto as Liam!!
double ditto! I was going to say you cant state a price without knowing how many circuits, but £250 to £400 is more like it for a proper job. And not
two hours with testing.
You certainly dont need a new board to get a boiler in. You would at worst have to have your earthing sorted (which can actually be earthed anywhere
if necessary) and an inline rcd on the circuit powering the boiler.
[Edited on 7/7/10 by JoelP]
