Fixing a leaking tap
Ninehigh - 16/11/10 at 12:12 PM
Anyone know how to fix a tap that's leaking from the bit where you turn the water on and off? Problem is it's the tap that turns the house water on and off...
prawnabie - 16/11/10 at 12:20 PM
Turn the stopcock off outside and replace the tap.
r1_pete - 16/11/10 at 12:22 PM
if its a stop tap like the one below, give the gland nut (arrowed) a nip up, it squeezes a fibre seal against the shaft and a nip will often stop a weep.
Image deleted by owner
BenB - 16/11/10 at 12:27 PM
As said get a spanner on the nut near the spindle and tighten it. Otherwise it'll mean turning off the main stopcock on the perimeter of the property and then doing it that way but it's a PITA unless you've got some kind of freezing kit because it'll mean draining down the whole cold water feed.
daviep - 16/11/10 at 01:30 PM
If tightening the gland doesn't stop the drip,
1:close the stop cock
2: back the gland nut right off slide and it up the spindle out the way
3: put a few wraps of ptfe tape around the spindle (below the gland nut) not too tightly
4: slide gland nut and ptfe back down the spindle
5: nip the gland nut up very gently
6: open stop cock
7: if there is still a drip nip the gland nut up a bit more.
cliftyhanger - 16/11/10 at 02:00 PM
If it is all seized (happens a lot IME) then you will need to replace the tap. They really need turning off and back on every now and again. Thesedays I replace with peglar 1/4 turn lever valves, full bore ones. They seem to be pretty good.
I avoid the unbranded cheaper ones, saving a couple of squid can be a false economy
Ninehigh - 16/11/10 at 02:37 PM
The stop tap will turn on and off, but that gland nut won't move. Hopefully we've got the right stop tap outside (can only see one about) which way does it turn off btw cos the kitchen tap has been running for about 20 mins now and nothing's happening..
r1_pete - 16/11/10 at 02:41 PM
clockwise
Ninehigh - 16/11/10 at 02:58 PM
Yeah stoptap outside isn't doing a thing...
r1_pete - 16/11/10 at 04:05 PM
As long as it is beyond your boundary that is the local water authorities responsibility.
cliftyhanger - 16/11/10 at 05:24 PM
is it a plastic tap thing outside? these seem to just rotate, but turn off every 1/4 turn.
A place I own didn't even have a stopcock outside. Took the waterboard a few weeks to come along and fit one (and fix the leak their side)
Ninehigh - 16/11/10 at 05:40 PM
Yeah there's a plastic tap thing, but doesn't matter which way or how much we turn it nothing changes...
So now we've told the water people, who are coming out "today" which in my experience means I'll ring them thursday and tell them to get their f**king a***es out NOW
macc man - 16/11/10 at 06:25 PM
If its a combined meter and stop tap you will probably find the handle has rounded off where it goes into the boss. you can usually move it with pliers. Happens all the time.
JoelP - 16/11/10 at 07:06 PM
daviep is correct, you dont need to isolate the outside supply.
When you turn off the inside stop tap, you can completely remove the gland nut, and only a small trickle will come out. The gland nut is to seal the shaft, not to hold it in! Re pack it and you should be sorted. We do this often.
JoelP - 16/11/10 at 07:09 PM
I may be wrong but im pretty sure they have an obligation to supply a point of isolation, so it doesnt matter what side of the boundary its on.
Ninehigh, if you do need the waterboard out, tell them there is a baby or elderly person in the house. You get faster service.
Ninehigh - 16/11/10 at 09:11 PM
The gland nut is a bit rounded, wouldn't move...
Water board guy came out, turns out we were turning next door's water on and off all day!
I'll have a go at fixing it when it's off
McLannahan - 16/11/10 at 09:33 PM
Classic - hope they weren't having a shower at any point!
Ninehigh - 19/11/10 at 09:04 PM
Well "fixed"
I hope!
New tap, old one is fubared and about 30 years old.
I'm just praying the damp there is condensation (warm kitchen, very cold water) and not leaking
Also the pipes bang somewhere now if you have the kitchen tap on full and shut it off quick, oh well no big deal on that one
Thanks for the help
