Does anyone have one of these?
I was thinking of buying one to improve my iphone gps pickup.
What's your opinion?
Got a Tomtom One. Good bit of kit. I use the pocketgpsworld.com speed camera files, as its cheaper than tomtoms.
although I only update before going away from my normal teritory.
Not that I speed, its the ones in the towns etc, that catch you out when you are paying more attention to where u are going etc.
I find the POI (Points of Interest) most useful.
In hindsight I would have preferred the wider screen as I am an old fart and my eyesight isnt that good for small print without my reading glasses.
Hence wanting a bigger screen!
Just my 2d's worth.
I have the iphone and tom tom kit. Its the only way my gps will work inside my car, so yes get one.
The only exception is if you have a heated windscreen as I believe they block the signals? Dont think the tom tom has an external anntena socket.
Check the reviews online as they are quite mixed. Some reckon it didn't improve the poor signal, though I'm sure it works for most. I find my iPhone Tomtom works fine without it, don't know why they would be different ....
I have a heated front screen (Ford Mundaneo)
I run 3 GPS's in the front screen (one in each top corner, and the tomtom bottom right), and the tomtom works fine. Just a little slow in locking
up.
One of the others loses lock when in narrow streets with at least 3 floors of buildings either side.
For those that want to know why I run 3 GPS, its 1 x Tomtom, 1 X analogue Amateur Position Reporting System, and 1 x Digital APRS)
Yep.. maybe a bit on the geeky side
Not a major problem, but some screens have an open section so GPS's work better.
Hope this helps.
I still think TomTom is the best satnav standalone but don't have it on my iphone due cost. I have co-pilot on iphone which is considerably
cheaper but I don't like it so much - maybe I'm less used to it. It works well without any in-car kit, ie good signal etc. So not sure why
TomTom needs the kit for signal boosting so much.
Incidentally, there is a free turn-by-turn satnav app: NavFree
Not sure about it yet, it seems OK if you follow the route but is less good if you go off route - it took a long time telling me to turn round, until
it realised going straight on was better.
Thanks for the feed back.
I found i was past the junction before the iphone tomtom caught up.
I have bought a tomtom car kit for the iphone of ebay.
I looked at some reviews which seems to say the improvements are more noticable on the 3G and less so on the 3GS.
I'll let you know the results.
