Hi Guys,
My design project at uni this year is to design a two stroke compression ignition engine for a model airplane capable of producing 0.06BHP at 12000
RPM.
I am looking to find different specifications of different engines already on the market to help with my decisions of bore/stroke ratio, compression
ratio, capacity, displacement etc.
Does anyone know anything or know when i can find any general information with regards to this?
Mikkel
Drop these guys a line. http://www.eifflaender.com/ They make some cracking little engines.
Try speaking to PAW (Progress Aero Works) who are/were a UK manufacturer of many years of diesels.
also if you can get hold of him, Ken Morrisey from Irvine engines is a mind of useless info on diesels and ex brit and world champion.
as im sure you are aware, glow plug motors are semi compression ignition motors too, iev known them run with blown plug elements purely on the
compression, albeit a bit off tune.
another vital firm to speak to is Model Technics in shoeburyness, they are the UKs biggest fuel blender and will give you the low down on fuel specs,
which are of course linked to the desired output of your motor project. Often the racier fuels require the carb/Compression settings to be near spot
on, whereas their Easy Start fuels the settings can be a fair bit off and the thing will still fire up (usually back firing and whacking the hell
outta ya finger!)
CNH
I haven't seen a diesel R/C engine for some years, they were mostly available in Europe, easily distinguished from Nitro engines as there is a
wing nut on the top of the cylinder head to raise and lower the compression for starting and running, tuning.
Have a look on ebay or at hobby shops that have been in business for some time.
Ive seen a few diesel conversions on nitro engines at my local R/C club.
Cheers for all the info guys,
Will try get in touch with them
That's who I linked to![]()
Have a look at Davis Diesels in the states, they do conversion kits![]()
Diesel smells though....
not sure on the power of it but i have some plans for a 0.1cc diesel that i started building as an apprentice. send me your email if you want a copy
Have a look here.
http://www.hemingwaykits.com/acatalog/The_Sparey_5cc_Engine___L_W_Sparey.html
