Some months ago my 'not very old' GNR TS902W monitor stopped working , and developed a strange ticking noise from the speakers, I plugged in
a spare and put the GNR to one side until I could bring myself to take it to the tip.
In the meantime I did a bit of research on zee web , and came up with some interesting stuff relating to capacitors.
Apparently most often when an LCD fails its the capacitors..........
So today, before I binned it i thought ,nothing to lose and opened it up, I noticed that some of the capacitors where bulging , and although the
circuit board was quite symetrical , some of the capacitors where 16v where most where 25v.
Coincidently the caps that where bulging where the 16v ones!, so I nipped down to Maplin and bought 7 new capacitors for £2.49, came back and
soldered them in ,threw it back together and **** me it worked, my flabber was truly gasted as I don't seem to have much luck with internet
tips!
So top tip check your comp components for ' Capacitor Plague' as wiki calls it .
I have a feeling that the day my monitor was built they ran out of 25v caps, and just put in what they had , I blame the Chinese ,British Leyland
would never do that kind of thing
well known in switch mode PSU's especially the ones that get warm,...
I have a feeling that the day my monitor was built they ran out of 25v caps, and just put in what they had , I blame the Chinese ,British Leyland would never do that kind of thing
Frank Harrison would be proud of you
I am also using a monitor that had the same problem, I found that it is a very common problem and supposedly due to some one in China ripping off the
formula for the electrolyte in them, from another company but missing out one vital ingredient to save a few pence causing the ally inside to react
and corrode destroying the capacitor.Unfortunately that particular company produced millions of dud components affecting most types of electronic
equipment.
Paul
Looking at this through a a repaired monitor.
Cap's were changed, but one of the drive fets had gone as well.
Cap. problem is on a lot of products. Mother boards, PSU's etc.
At one point there were a lot of Dell GX270 desktop computers suffereing with blown caps
Repaired a Samsung 940mw tv/monitor by replacing 8 capacitors , it madness!!
The Frank Harrison that Westf27 is my old science teacher (I think) , we went to the same school ,it was quite good 'cos it was approved!
