http://www.locostbuilders.co.uk/forum/8/viewthread.php?tid=151113
Hi all after all my problems with sky they are giving me a FREE sky + hd box
What i would like to know is if i keep my old box / dish can i use it in my caravan for freesat ? if so do i need a card from sky ? to make it work
If not Sky who from ?
Jacko
You can use it anywhere you like but you will need a card from Sky to view Freesat.
You will only get a handfull of channells if you just plug it in with no card.
You can add the channells manually. Do a search on google and people offering all sorts on ebay..
[Edited on 6/3/11 by big_wasa]
You can't use a Sky box for Freesat.
What you see on Sky for free are Free to view satellite channels. There is a very distinct difference
try just freesat info on website
http://www.freesat.co.uk/
You also lose the PVR functionality.
Put the spare 'Murdoch money box' in the caravan and rig it up. When you leave home, remove 'Murdoch card' from home 'Murdoch
money box', slip it in your wallet and take it with you.
When you get to your caravan, remove the 'Murdoch card' from your wallet and slip it into the caravan 'Murdoch money box'.
Unless you can be in two places, watching two lots of 'Murdoch money' at the same time, I cannot see any drawbacks to this!
My brother-in-law does this every Friday night when he leaves home for his caravan.
Result ?
Regards.
Jon.
Not sure that works all the time. I tried using my parents card in my old sky box and it said something like 'this is not the correct card,
please call sky on.... '
So don't pin your hopes on that working.
Nope, as I wrote above, Freesat is NOT available on Sky boxes
Yawn.
http://www.sky.com/shop/freesat/home/
What is the pvr ?
Originally posted by stevebubs
Yawn.
What is the pvr ?
The ability to record programmes or play back anything you've recorded before.
There seems to be some confusion here between 'Freesat' (run by Freeview), and 'Freesat from Sky' (run by Sky).
Yes, i did correct myself above after reading the link. But just removing a card from a Sky box still does not make it freesat. They are just the free
to view channels.
But, does anyone else see the irony on spending £25 for something called FREEsat ?
Yes, i did correct myself above after reading the link. But just removing a card from a Sky box still does not make it freesat. They are just the free to view channels.
yes it is lol
anyway, you can't just remove the card from one box and plug it in the other when you go to the caravan as suggested above, as you'd have to phone up to pair the card to the old box, then phone to pair it to the new box when you get home. there is a way you can do it yourself through the box, but it would have to be in a phone line to do that.
freesat yes you can do it. if you've got no card in the box you'll get some channels, bbc, itv etc, a freesat card (one off payment of about £20 from sky i think?) will give you all freeview channels, and a few more.
with no card in, you'll automatically get bbc london, the freesat card will set you to the correct local region
i er, had the misfortune of working for sky for a while last year...
don't think the engineer will, or at least they're not supposed to
you can always ask
edit: foret that, they definitely won't have cards on the van, cards are always posted out, because they are set against your name and address,
engineers never have any sort of cards on the van.
[Edited on 6/3/11 by blakep82]
Thankyou all for this superb info his forum know every thing
Jacko
^ that does happen in some cases, but most cases, the tv will show up with a message saying, 'this is the wrong viewing card for this sky box,
please call customer services for assistance' where the card will have to be paired with the new one. again, i worked for sky until october, and
had this same question about 30 times a day lol
once a card is paired with a box, it will only working with 1 particular box. but as before, there are some instances where it works in others. you
might be lucky, but i wouldn't count on it
^ that does happen in some cases, but most cases, the tv will show up with a message saying, 'this is the wrong viewing card for this sky box, please call customer services for assistance' where the card will have to be paired with the new one. again, i worked for sky until october, and had this same question about 30 times a day lol
once a card is paired with a box, it will only working with 1 particular box. but as before, there are some instances where it works in others. you might be lucky, but i wouldn't count on it
weird, must be something to do with the card then....
You CAN swap cards from box to box without the need to specifically pair it as I've been doing it for ages on different cards and boxes. You
won't be able to get the movies or sports on a different box though but the other packages work.
Every time they send out new cards to everybody then this feature stops though which is when you get the 'this is the wrong card for this
box' message - When you think about it what people would be able to do is give their old card to a friend/family member etc to use until it is
turned off and use the new one they have recieved themselves.
I know because I've had no trouble swapping before a new viewing card roll out and then couldn't while it was in progress and quite a while
after it had finished. I've just this minute popped the card out my sky HD box and popped it into a spare sky+ upstairs and can get all the
subscription stuff no problem again.
You won't be able to live pause or record the subscription channels though iirc but you CAN pause/record if its a free to air (FTA) channels
(can't be arsed to go up and swap it again!)
Oh and there are only a few channels that need a £20 or £25 card from sky for you to be able to view them - it used to be more but the channels went
free to air - It used to be itv,channel 4,channel 5, sky travel/sky 3 but think its only sky travel/sky3 and sky sports news now.
G
[Edited on 7/3/11 by Mr G]
