Garage doors
tegwin - 20/3/11 at 06:33 PM
So the house is more or less finished, which means I can get onto the bit I want to do the most... the garage/workshop!!
First thing to do is to build a new roof (loosing the asbestos) and then fit a new door!)
The current door is very low and a seriously bent, steel up and over thing...
What I want ideally is a roller type door with either remote fob, or if its cheaper, just a key switch....
Anyone got any recomendations for lo-cost roller doors!? Dont mind doing some of the donkey work myself if it means I can get one for less....
Anyone any experience of living with roller type doors?! Anything I should be looking out for?
jacko - 20/3/11 at 06:44 PM
Whiting doors are good thats what i use to fit in box vans
Mr Whippy - 20/3/11 at 06:47 PM
yip I have fitted both roller and sectional, the roller one is my sisters and I was not impressed with as it's flimsy and not very well held in its tracks. It's also very noisy to use, kind of clatters when moving
I have a Hormann 3m sectional door with remote and I can't fault it one bit. Been totally reliable and wind and water tight. Think it cost me £1200 which was a bit mad but it's double skinned filled with insulation too. I managed to fit it myself on a windy day no bother and it just bolted together very easily. Would very much recommend one.
[Edited on 20/3/11 by Mr Whippy]
skippad - 20/3/11 at 07:00 PM
I got a Henderson insulated roller shutter garage door fitted about a month ago.
Nice and smooth up and down and airtight!
Put a fan heater on and warmed up pretty quick.
I had wood doors on which rotted away (they were on for nearly 20yrs which was good age)
But these are brilliant and were cheaper than wood equivalent.
will121 - 20/3/11 at 07:19 PM
Another thing to consider is how much head room have you got above the door and what there is to mount the roller door too
Mr Whippy - 20/3/11 at 09:08 PM
good point, a normal door ends up with a roll about 1 1/2 in diameter. My sisters one ended up in the garage loft area. If you have a flat roof I doubt you'd have the space
bigruss - 20/3/11 at 09:24 PM
Another vote for the Hormann sectional. Not locost, but just fantastic
Xtreme Kermit - 20/3/11 at 10:37 PM
I'm in the Market for a new door. I am after a roller shutter as I have the height above the door.
Any good or bad makes to watch out for?
