Interesting site
mangogrooveworkshop - 14/7/04 at 02:25 AM
http://www.birkinamerica.com/_home2.htm
$10824
STARTER CHASSIS- NOT ASSEMBLED
All Birkin components are new and no donor car parts are required
Group 1-Body Chassis Group 3- Front Suspension
Aluminum Body, Brake & Fuel Line Kit, Fuel Tank Kit, Electrical Loom Kit, Bonnet Catch Kit, Boot Liner Kit, Scuttle Kit, Bonnet Kit, Mudguard Kit (unpainted), Cycle Fender Kit (unpainted), Inner Side Panel Kit, Nose and Grill Kit (unpainted), S3 Diffuser kit. Lower Wishbone Kit, Upper Wishbone Kit, Stabilizer Bar Kit, Upright Kit 100 PCD, Linkage Kit.
Group 2- Steering and Pedals Group 5 - Chassis Accessories
Steering Rack Kit, Steering Column Kit, Pedal Box Kit. Radiator Kit, Seat Mounting Kit, Console Kit, Wiper Motor Kit, Hand Brake Kit, Roll Bar Kit Spare Wheel Cradle Kit, Switch Kit.
Group 6-10 Optional Extras
Group 6 - Lights $889 Group 10 - Extras
Tail Light Kit, Headlight Kit, Wiring kit, Indicator Pilot Lights, Wiring and Switch Kit Fuel Sender Unit Kit - $129.00 Instrument Kit (no speedo) - $1,349.00 Mirror Kit - $135.00 Wheel and Tire Kit - $1,481.00 Reservoir Kit - $408.00 Master Cylinder Kit - $809.00 Cooling Fan & Horn Kit - $300.00 Shock Absorber Kit - $1,246.00 Spare Wheel Assembly Kit - $452.00 Stone Guard Kit - $28.00 Seatbelt Kit - $109.00 Battery Mounting Kit - $163.00 Accessory Kit - $29.00 Windscreen Switch KiT - $60.00 Fuel Line & Pump Kit (for carbs only) - $115.00 Heater Kit - $153.00 Badge Kit - $40.00 Steering Wheel Kit (LHD) - $220.00
Group 7 - Windscreen & Wipers $566
Wiper Assembly Kit Windscreen Washer Kit Windscreen Heater Kit Windscreen Mounting Kit Wiper Arm Kit
Group 8 - Upholstery & Interior $409
Back/rest Panel Kit, Carpet Kit, Seat Kit
Group 9 - Weather Equipment $1218
Boot Cover Kit, Tonneau Cover Kit, Hood Assembly Kit, Side Screen Kit, Wind Deflector Kit
PLEASE REFER TO THE ORDER FORM FOR OTHER OPTIONS
10,824.00 USD
United States Dollars = 5,823.85 GBP
United Kingdom Pounds
1 USD = 0.538049 GBP 1 GBP = 1.85857 USD
[Edited on 14-7-04 by mangogrooveworkshop]
Findlay234 - 14/7/04 at 08:50 AM
and one of the best sevens on the market....... the $10824 only gives you packages 1-5. so its not gonna be that cheap. better than a westy IMHO.
Alan B - 14/7/04 at 01:23 PM
Yeah Birkins are very nice.....every bit as good as Cateringvans IMO, as they should be....bloodline and all that....
