OT:- Can I bond Plyboard to metal (mild steel) angle with normal PU bond???
Steve Hignett - 12/5/12 at 05:11 PM
Hi All,
As above, I have a spare tube of PU (normal stuff in black for bonding FG wings to wingstays) and wondered whether I could sucessfully make a relatively arduous task much easier! (I don't fancy drilling a hundred holes in 3mm steel angle iron!)
So, assuming I key both surfaces, what do people reckon the chances are that I will get a good bond? Other things to note are that this is not a kitcar, and is a trailer. Therefore, not structural as anything weighing on the bonded join will only serve to press the mating faces together...
Thanks in advance for constructive feedback...
liam.mccaffrey - 12/5/12 at 05:21 PM
yes, I wouldnt hesitate to do that
[Edited on 12/5/12 by liam.mccaffrey]
jacko - 12/5/12 at 05:24 PM
Yes go for it its what we use at work in the bus industry
Steve Hignett - 12/5/12 at 07:07 PM
Asante Gents..........
welderman - 12/5/12 at 08:46 PM
It's a very robust trailer
scootz - 12/5/12 at 08:48 PM
This robust?
welderman - 12/5/12 at 09:02 PM
Not quite.
nick205 - 12/5/12 at 09:41 PM
Originally posted by scootz
This robust?
You always go too far Scootz!
When we talk of a trailer we mean a bastardised caravan chassis which we hope might suffice to drag a kit car to the track and back without giving out.....not the sort of trailer you would buy and then sell at less than purchase price
