doesn't look much like a locost but still fun!
http://www.ebaumsworld.com/parkinggarage.html
The puzzle would be more fun for me if the directional symbols were easier to see so I could try to use my "intellect" to map out a path from the get-go instead of trial & error at each intersection from different directions until I knew what to expect. Maybe it's just my video settings - or maybe just my tired old eyes. After getting out I thought I was done, but there appeared another parking garage. Am I correct that the subsequent garages are all the same and not more difficult levels?
Clearly it's not possible to complete- otherwise I would have done so!
James
it is possible takes a while though
I somehow managed it after about 5 minutes, good game though although using the keyboard arrows instead of the mouse would be much easier
Mine must be the same as James' because I too have failed....
John
easy
good fun though
I printed it and used an old fashioned pencil to draw the route. It is definitely possible, just work backwards
done it, use the bottom left to do a u-turn then back along the bottom and out...
Ned.
I can't even get the thing to reverse, it must have a bike engine.
Print us the solution Mook.
ok try this:
fwd, fwd, r, fwd, l, l, fwd, fwd, r, r, r, l, l, r, fwd, r, fwd,fwd,fwd,r,fwd,r,r,r,l,l, you can see it from there (if I have tryped it correctleyy)
something like this?
Image deleted by owner
[Edited on 9/9/04 by ned]
indeed
