My brother in law is in a fairly old house, and is needing to put some lights into his loft. The current lights for the entire house is fed off one
twin and earth (fairly beefy from memory) from one RCD to a really old looking junction box. From here, there's various connectors inside it that
feed power and switch to each of the lights.
What he's done to provide the lights in the loft is take a 2.5mm T&E feed from the main block (connected directly to the original T&E
from the mains), feed that to another junction box then do the same thing to feed the remaining lights.
So there's basically one spur, with two star/fan (not sure of the correct term) fed off it.
I'm sure it's not the best way to do it, but would it pass the relevant tests to get the certification?
[Edited on 2/9/12 by Slimy38]
Not a leccy, but first thing is it will deffo need to be fused down, really to 3 or 5 amps. That is what was done 20m years ago on my loft
conversion.
Otherwise there should be no real issues, unless the regs have outlawed fused spurs now?
Sorry Mate but that's a NO. All of it is wrong! None of it is right! You need a competent electrician or it'll all end in tears (not to
mention smoke and flames). NO spurs of any kind let alone "star" configurations are allowed. Lighting is a radial circuit with no exceptions
and each run is restricted in length according to cable size and protection value (fuse/trip size). I could go on but to be honest if you don't
know about the above then the best idea is to not touch.
Without even looking from what you have said it needs a rewire to pass a 17th edition test. Sorry but that is about the size of it I'm afraid.
And yes I am qualified!
U2U me and I'll give you my no. and I will happily talk to you and give advice but you are really need a professional to take a look from what
you have said.
Cheers Si.
Originally posted by cliftyhanger
Not a leccy, but first thing is it will deffo need to be fused down, really to 3 or 5 amps. That is what was done 20m years ago on my loft conversion.
not all of this is true. you can re-wire houses using junction box method if you want to. but the installation sounds bad as it is. why has he used a
2.5mm? why is the lighting main 'beefy'
shoulod be 1.0 or 1.5 mm2. i would NEVER certify a DIY job, EVER!
So lighting rings have gone? every light is now radial?
I guess there is/was a reason, but I am struggling to think of one. Unless it is something to do with bathrooms now needing their own mcb for the
light? or something like that from what I have picked up.
Re the spur in my house, I was just referring to what was done on my place. And as a reassurance, lighting rings still passed my safety certificates
when they were last done, so not dangerous. 90%+ of the country still has them (at a guess!)
[Edited on 2/9/12 by cliftyhanger]
not all of this is true. you can re-wire houses using junction box method if you want to. but the installation sounds bad as it is. why has he used a 2.5mm? why is the lighting main 'beefy'
I guess there is/was a reason, but I am struggling to think of one. Unless it is something to do with bathrooms now needing their own mcb for the light? or something like that from what I have picked up.
Re the spur in my house, I was just referring to what was done on my place. And as a reassurance, lighting rings still passed my safety certificates when they were last done, so not dangerous. 90%+ of the country still has them (at a guess!)
Interesting, thanks. The original wiring looks like it was done with the house, although it was a council house so it 'should' have been
checked on a regular basis until they bought it about ten years ago.
When I first looked at the box I'd not seen anything like it to be honest, but I did my sparky training back when I was still on my
apprenticeship, about twenty years ago now. It is a bit difficult to describe, while I can only describe it as a junction box it's not the round
things that most people would recognise. It's about ten inches square, with a large block at the bottom where all the lives and neutrals come
into, then a block on the right where each of the switches come into. Does that sound familiar to anyone?
It does sound like tapping on to that is the wrong approach, I'll have a look to see what other options he has. Although part of it may be my
misuse of the term 'spur', basically it's a single connection to the distribution unit rather than the double connection that a ring
main would use.
Here you go, this is quite clear
http://www.diynot.com/wiki/electrics:lighting:lighting_circuit_layouts
Yep, it's nothing like any of them!
I'll try and get a photo of it.
Although that link may have solved a particular problem of my own, I have a 'buzzy' lightswitch that I couldn't figure out how it had
been wired. Looks like it's the 'looping at switches' method so now I know where the wires going I can take a look at it.
So, if I read this right - every lighting point has to be run back ( via switch ) to the distribution board ?
Is that correct ?
This head makes me shake my head to be honest. If he doesnt know what to do, he shouldnt be doing it. And he has no chance at all of getting someone
to sign it off - its hard enough to get stuff signed off if its done according to the regs, nevermind if it looks diy.
Are you sure its an rcd feeding it all and not an mcb? If its an old house, it would only have an rcd if it had been rewired at some point, and it
wouldnt have an rcd feeding one circuit unless it was a recent modification.
A photo of the consumer unit would help you get advice, along with photos of the junction boxes and cables.
A light circuit is typically on a 6amp mcb, a big circuit might be 10a. If its a single light, then a 3a fuse in a fused connection unit would be
suitable. Cable would be 1 or 1.5mm t&e.
Is that correct ?
Is that correct ?
Originally posted by JoelPAre you sure its an rcd feeding it all and not an mcb? If its an old house, it would only have an rcd if it had been rewired at some point, and it wouldnt have an rcd feeding one circuit unless it was a recent modification.
A light circuit is typically on a 6amp mcb, a big circuit might be 10a. If its a single light, then a 3a fuse in a fused connection unit would be suitable. Cable would be 1 or 1.5mm t&e.
it sounds like its just a standard junction box method to me! although old. i also know its the protective device thats important but anyone in the know would not wire a 2.5 which is already fed from a 1.0mm.
Originally posted by Strontium Dog
As I said earlier, sounds like it needs a professional to asses it and may well and likely does need extensive remedial work!
[Edited on 2/9/12 by Strontium Dog]
They're looking to rent it out so they need the certificates quite quickly.
I've suggested an initial review by someone better than me just to see what needs to be done, then I'll come back and assist with the work
before getting the final paperwork sorted. quote:
Already suggested it as soon as I started to see the responses!They're looking to rent it out so they need the certificates quite quickly. I've suggested an initial review by someone better than me just to see what needs to be done, then I'll come back and assist with the work before getting the final paperwork sorted.
I don't mind doing electrical stuff and consider myself reasonably competent, but I know my limits.
If they are renting it, just get a spark in to do an inspection and get him to sort it out at the same time. They arent that expensive! Not worth an amateur fiddling about when a spark will do it twice as fast including filling in the paperwork!
unless when th spark gets there and finds no main bonds etc. then he aint gonna connect up and sign off!
imho i would also get someone in but it could open a serious can of worms as loads of remedial work could be required.
youd be amazed at some installations
Main bonds? Are you talking about equipotential bonding? That was covered when he replaced the kitchen, bathroom and central heating.
But I'm sure something else is going to come out of the woodwork... or in this case, plasterboard...
