I know completely off topic but as always there is a fountain of knowledge in here
We are moving house shortly and looking to extend when we move in, the problem Im having is working out the roof, from the plan and photo below we
want to square off the L share and put an extension where the table and chairs in approx 3x4m. the problems i see are:
1. The current flat roof looks like it falls towards the place where i want the extension
2. the current flat roof is attached to the neighbors house
3. We want to remove the 80% of the existing wall an replace with some sort of RSJ so the current kitchen will become one big room
I was reading that iff you have over 30% of your roof flat it makes it hard t0 get insurance and this would take us near the 30 bu as we only want to
put 2 new walls in and the the room is quite deep (4m) im not sure we could support a pitch roof
Any comments advice welcome
<advert>
My cousin Jason @Burlens http://www.burlens.com/ should be able to point you in the right direction.
Depending on where you are (regs change between county apparently) he should be able to answer your question.
</advert>
No help but that kitchen is a terrible layout as is, not surprised you want to change it!
yeah its one of those things, we liked the house and location so figured extending it would be fine
then the more I look at it and think about it without actually having access to the house yet the more complications I can see
