Morning all,
A question for the forum...
In the steps of planning some upgrades to my daughter's bedroom. One planned change is to convert what is currently a door-less wardrobe space
in her room into a wardrobe. Making and fitting shelves, rails etc. is easy enough for me, but the room is 7' x 8' and I think would
benefit from a pair of sliding wardrobe doors rather than normal hinged doors. Again, I'm happy installing them, but not sure what to buy.
Can anyone recommend (or un-recommend) a place to get doors from?
The existing timber door frame is 1,080mm wide x 2,005mm high so they may need to be made to measure.
With a new bed (and two other kids) etc. to buy I'm on a budget so low cost (DIY) works for me
Thanks,
Nick
A good starting point? CONTEMPORARY MADE TO MEASURE FITTED SLIDING MIRROR WARDROBE DOORS & TRACK SET
That's a shame. I have 2, approx 29 inches wide by 90 inches high. Free!
Would be ok if your good with a glass cutter.
Problem is I'm in Bristol.
Check out Howdens if there's a depot near to you. Unsure if they deal with public or just trade, but they do a variety of doors.
I designed made my own a few months back as I wanted a fairly bespoke set up (I wanted 3 doors on 3 tracks to get max opening possible.
I bought these tracks and runners direct from the supplier http://www.bimak.co.uk/mini
Cost me about £60 for the above, but that was enough to two 1800mm wide wardrobes, each with 3 tracks.
I bought Ikea Pax doors but from the hinged range which were between £15 and £35 each (colour and style pendent).
I used an mdf skirting as the base and framing.
Including extras such as timber packers for top frame, screws etc Id say the 2 wardrobes cost me £300 but with no internal framework. More than I
wanted to spend but got me exactly what I wanted.
WardrobeStart
LeftFrame
FrameFinished
Wardrobe4
I also added some LED lighting to snaz it up!
Would be ok if your good with a glass cutter.![]()
Including extras such as timber packers for top frame, screws etc Id say the 2 wardrobes cost me £300 but with no internal framework. More than I wanted to spend but got me exactly what I wanted.
WardrobeStart
LeftFrame
FrameFinished
Wardrobe4
I'm just about to start on my spare room and have found homebase to have a decent range. doors from £66 each and runners from £30 make it cheap
and they get great reviews too.
the top can be spaced down with timber and painted if your room is tall.
He's already said what size his doorframe is, and most of those homebase/B&Q sliders are too tall - unless he can expand the opening
vertically. The PAX idea looks like a good solution, and nicely done.
The problem I found, as did loggyboy, is that sliding doors never give you full access to the inside - there is always a door in the way, although 3
doors is better than 2 as he says, but then 3 door thicknesses take up space.
I boxed in an alcove and this time used bifold folding doors. You need some space in the room, although that is only half a door's width, but
you get great access to the wardrobe. A pair of these ones from B&Q would fit your doorframe almost exactly. They are a bit of a fiddle to fit
and adjust but look good: http://www.diy.com/departments/4-panel-primed-woodgrain-effect-internal-bi-fold-door-h1950mm-w595mm/42515_BQ.prd
Originally posted by geoff shep
He's already said what size his doorframe is, and most of those homebase/B&Q sliders are too tall - unless he can expand the opening vertically. The PAX idea looks like a good solution, and nicely done.
The problem I found, as did loggyboy, is that sliding doors never give you full access to the inside - there is always a door in the way, although 3 doors is better than 2 as he says, but then 3 door thicknesses take up space.
I boxed in an alcove and this time used bifold folding doors. You need some space in the room, although that is only half a door's width, but you get great access to the wardrobe. A pair of these ones from B&Q would fit your doorframe almost exactly. They are a bit of a fiddle to fit and adjust but look good: http://www.diy.com/departments/4-panel-primed-woodgrain-effect-internal-bi-fold-door-h1950mm-w595mm/42515_BQ.prd
. A behaviour we're trying to instill/encourage in her.
