Bit of a random question but..... does anyone know if you can by mounting brackets for a towel radiator that are shorter than standard ones? I think
the normal ones are about 80-90mm. Ideally im after ones that are the same depth as a normal wall mounted rad bracket. If not ill cut down the ones i
have
N1
Sure the general length of the shorter ones are 60mm iirc. In an old property I needed to mount one closer to the wall due to access through the door. I cut / tweaked no issues
I tend to cut the plastic ones down. The metal type are harder to shorten and may need the fixing hole drilling and tapping.
Not a big job.
