Afternoon all,
Have a Dyson V7 cordless vacuum cleaner. Excellent to use and been very pleased with it.
Despite charging it (on the charging dock it came with) the run time decreased from around 30 minutes to now not working.
I've removed the battery pack and tested across the charging input contacts with a multi-meter and get 2-300 milli Volts. The rating on the
label is 21.6 Volts.
Questions
1. Is my multi-meter test valid and indicating a worn outbattery pack?
2. If not, how else can I test it?
Not wanting to spend out £65 on a new (genuine Dyson) battery without some certainty thats the problem.
Some advanced battery management systems won't show the full voltage unless all the connections are made properly - but I doubt even Dyson would
be that fussy.
There is a high probability that the battery is knackered. Do you have access to another battery as a comparison?
Not another Dyson battery, only AA rechargeable batteries. Looking at the size/shape of the Dyson battery pack I suspect it's 6 x 18650 cells inside it.
Replaced our V6 battery with a generic one from amazon approx. £40 and has lasted way better than the original, been in use for for 5 years now.
Branded "flylinktech" however you pay your money and take your chance with that kind of stuff.
Regards
A voltage test means nothing without having a substantial load on it, if the voltage was holding up under load then it would be working
daviep
Noted.
I've ordered from Amazon "BATOOL".
Higher mAH rating £33.
Arriving Tuesday, will report success.
russbost
Noted also.
No obvious way of getting a load on it and testing. Too much plastic!
Mine is an amazon replacement too. Its been perfect.
My Amazon purchase "BATOOL" Dyson V7 spec. battery pack arrived yesterday afternoon. Unpacked and all seemed good, it looked right, the
spec. label read correct and it fits correctly. Fitted it to the vacuum and it worked (ggod start). Instructions advised to charge, so it went back
in the Dyson charger. To be tested vacuuming this evening when I get home from work.
All looking good so far.
Time will tell how well it performs and lasts!
Some extra feedback...
The purchased battery didn't do the job. Worked for a few minutes then back to pulsing and no performance.
Returned and refunded no issue.
Flylinktech (as recommended above) now on it's way from Amazon. Last chance then it's new (corded) vacuum time.
Flylinktech battery + replacement filters arrived yesterday. Fitted and been charging overnight.
Testing later today.
Ours pulses when it needs a clean. Every month or so I have to strip it down and give it a clean with my garage Henry, then it'll carry on
working.
I find them very irritating to be honest, but my wife loves it. I'll stick to my 'so much suction it lifts the carpets' Henry.
We used a fleet of V7's in work for lightweight spot cleaning duties. Batteries all lasted a year or so and then failed. I'm really not that impressed by battery tools I'm afraid, too fussy and too failure prone in general.
Had same problem - (pulsing then turning off) turned out to be blockage in the detachable "head". Not easily visible but found when tried to push a cable tie past the motorised bar sweeper into the centre of the "head" outlet.
Glad you didn't have to buy a new vac...
You and me both, money better spent on other things.
That would suck.
