Question for the LCB knowledge bank...
My kitchen mixer tap's developed a periodic drip. 99.9% sure it's the ceramic cartridge on the hot water side so purchased a pair of
replacement hot and cold cartridges to fit. Looks a simple enough job.
2mm Allen key to remove lever handle.
17mm spanner to remove cartridge.
Then reverse process to install replacement.
Anyone else done this and any words of wisdom - major do's / don'ts?
Sound obvious but do make sure they are exactly the same.
I have found that whilst the cartridge may fit into the tap body OK the length of the external thread where the shroud fits can be different as can
the length of the spline and the female thread where the screw that secures the lever goes.
John.
Turn off the stopcock first.
I have found that whilst the cartridge may fit into the tap body OK the length of the external thread where the shroud fits can be different as can the length of the spline and the female thread where the screw that secures the lever goes.
John.
Check whether hot and cold are different rotation directions for on - off. Mine were.
Every ceramic valve tap I've ever had has dripped within a few years. I don't know whether it's something in our water (it's
neutral to hard) or whether there's electrolytic corrosion going on, but the brass in the valve units have failed. All my taps now are of the
rubber washer type - easy and cheap to fix, as you can get a pack of rubber washers for a Pound or two from almost any hardware shop. Better than
having to send off a heap of money to a particular maker!
Luddite, who me?
Also the spline count does vary on the tap head shaft.
But with the few provisos the job is usually simple enough.
Every ceramic valve tap I've ever had has dripped within a few years. I don't know whether it's something in our water (it's neutral to hard) or whether there's electrolytic corrosion going on, but the brass in the valve units have failed. All my taps now are of the rubber washer type - easy and cheap to fix, as you can get a pack of rubber washers for a Pound or two from almost any hardware shop. Better than having to send off a heap of money to a particular maker!
Luddite, who me?
Some good advice above and if your fitting genuine cartridges you should be fine
Checking the mating face inside the tap for scale or corrosion before fitting the new cartridges
Luddite, who me?
Tap is 18 years old (as is the kitchen I fitted). I know this, because I fitted it just before first child who's now 17 yrs and 3 months.
Tap has been faultless up to now and we live (Hampshire) in a very hard water area. Regular kettle and shower head descaling required.
Replacement cartridges I've got are the same rotation directions (already checked).
How tight you do the cartridges affects the position of the handle when it's off. The splines only allow approx alignment. Check the handles line up satisfactorily before packing up - you can tweek by tightening the valve slightly.
perksy, indykid & JoelP
Thanks for the advice
1. Will make sure the mating faces are clean and damage free bfore installing the new cartridges.
2. Will prepare for the tap spout run back.
3. Will check hot/cold lever positions/operation as part of fitting new cartridges.
Job done - simples.
Parts easy to fit and dripping stopped.
Realise now how worn the old cartridges were.
