Light switch name help
Mr Whippy - 24/11/25 at 04:22 PM
Hi, one of the kids knocked the rocker off the hall light switch, I have been struggling to identify the model to buy another, it's by MK. Unfortunately all the online shops do not show the back of the switches so I cannot match it up. Even the packets in the shops don't let you see what it looks like on the back.
Any help would be much appreciated, thanks.
jacko - 24/11/25 at 06:13 PM
From what I have read it’s a intermediate switch not a two way switch
But I could be wrong
Graham
[Edited on 24/11/25 by jacko]
gremlin1234 - 24/11/25 at 06:32 PM
I think there is one of each, 1 intermediate, & 1 two way.
Mr Whippy - 24/11/25 at 07:30 PM
Well done
I put that description into google and it's brought up one that even has a picture of the back and it does look like the same terminals.
Many thanks for the help, I've never even heard of these
jacko - 24/11/25 at 08:02 PM
You are welcome
Where would you like we be without google
G
JoelP - 26/11/25 at 09:19 PM
FYI you can use an intermediate switch like a normal 2 way one if you just bridge one end and use it as common.
Mr Whippy - 26/11/25 at 11:55 PM
Thanks but I wasn't wanting to experiment with the wiring as these more complex setups are more than I know about and it worked fine till the kids knocked the switch off.
nick205 - 29/11/25 at 02:13 PM
Mr Whippy
Curious myself now as I've not come across these before.
Where is it fitted in your light switching setup?
gremlin1234 - 29/11/25 at 05:53 PM
Originally posted by nick205
Mr Whippy
they would normally be used on an intermediate landing (staircase) , with a passageway to the side.
ie, 3 way switching on staircase, plus two way on the first floor passage.
note also, if you can get a similar faceplate, you could just swap the gubbins/switch-modules to that, without disturbing any wiring.
nick205 - 29/11/25 at 10:47 PM
Mr Whippy
