My 1.9 diesel Kangoo has developed a problem
It seems to have air in the fuel lines but I've not ran it out of deisel? This causes the engine to run eratically and cuts out on occassion,
usually at the most inconvenient times!!
Does anyone has any idea how to bleed one of these engines????
Paul
Sounds more like fuel filter problems. If it needs bleeding it won't run.
You wont get air in the system if you haven't run out of fuel and not disturbed anything, Sounds more like a dirty filter have you had a new one
fitted lately?
Could be drawing air in through a loose pipe,faulty washers on a banjo fitting, seal fault on filter
Just a few ideas Gary
deffo go for fuel filter...may have water in it...happened to my xantia and it ran like poo
Colin,
poo can't run!
Just thought i would point that out!
I dunno Andy, I've had some pretty bad curries that've had that effect.
Mike
Originally posted by paul v6
My 1.9 diesel Kangoo has developed a problem![]()
It seems to have air in the fuel lines but I've not ran it out of deisel? This causes the engine to run eratically and cuts out on occassion, usually at the most inconvenient times!!
Paul
Hi John,
The problems you descibe are absolutely spot on, but its a 15 plate so post 2000??
Any ideas??
Paul
