Too good to be true? NTDWM.
http://cgi.ebay.co.uk/15BHP-Power-Mod-Rover-100-214-216-220-400-420-SI-GTI_W0QQitemZ8004190773QQcategoryZ32094QQssPageNameZWD4VQQrdZ1QQcmdZViewItem
[Edited on 2/10/05 by Mansfield]
i'm pretty sure it adjusts the value from the inlet air temperature sensor into the ECU, make the ECU think the air is warmer or something like
that, don't know if they work though.
Ray
Its basically a 10p (at most) resistor that replaces the air temp sensor so that the temp remains constantly lower. This puts more fuel in so might give you a bit more power, but won't be too good for your car and wont help the MPG as they claim!
it says this
How does it work?
It will modify any standard ECU by telling the ECU that the incoming air in the intake system is cold and so advances the ignition to compensate
producing more power. In many cases fuel economy is increased too. Power is increased by up to 15BHP and torque is increased significantly.
so, it must surely overfuel, so htf will that give better milage?
atb
steve
I put a similar thing in my 2.0 Audi TDi
feels a lot quicker, and an extra 3 mpg on my weekly average
colleague at work has a 1.9 SEAT and he gets extra mpg too
