Bogg Brothers have a Website
donut - 11/10/05 at 04:44 PM
Just to let you all know that Bogg Brothers now have a web site. It's still under construction and may change but it's up and ready for viewing.
www.boggbros.co.uk
Deckman001 - 11/10/05 at 04:46 PM
Their photo's need lightening up a bit matey while your at it !!
Jason
donut - 11/10/05 at 04:56 PM
The photo's are from them so they go on 'as is'
turn your brightness up on your monitor
Surrey Dave - 11/10/05 at 05:29 PM
Andy: !st time I've seen an MK indy/ Pinto with the exhaust out the left hand side.(top right homepage)
matt_claydon - 11/10/05 at 05:38 PM
Could do with an address somewhere on the site! (Unless I'm blind ;-)
donut - 11/10/05 at 05:40 PM
If you are at the site then you don't need the address!! - It's at the bottom of each page by the way
Dave - spookey eh!!
[Edited on 11/10/05 by donut]
iank - 11/10/05 at 06:29 PM
Dave - spookey eh!!
Think he might be after one of those old fashioned location things, you know the ones with a postcode Just a phone number on the contact us page.
donut - 11/10/05 at 06:31 PM
As i said it's under construction. The full address etc will be added tomorrow.
sheesh, give uz a chance!!
iank - 11/10/05 at 06:35 PM
donut - 11/10/05 at 07:03 PM
Contact page now updated
OK!!!
Rorty - 12/10/05 at 07:50 AM
What's that in the third picture down in the gallery?
donut - 12/10/05 at 10:07 AM
Bike carbs with inlet manifold. The one below that is a Fiesta i think.
Rorty - 12/10/05 at 12:44 PM
Third/fourth, Fiesta? How's that going to work? Has anyone seen it?
donut - 12/10/05 at 02:23 PM
I'll ask Steve when i speak to him next.
iank - 12/10/05 at 02:46 PM
Well it does look a bit lightweight, but it's just trailing arm suspension similar to that fitted to every mini ever made (including the Z-cars ones) isn't it. Or are you thinking of something else in the picture?
Rorty - 12/10/05 at 09:30 PM
I'm just curious. It looks very flimsy and seems to be fully trailing and not semi-trailing.
Maybe the small dark picture doesn't do it justice.
iank - 13/10/05 at 08:12 AM
Time for me to improve my educasion
OK Linky shows the difference.
So, yes it looks like fully trailing. The mini and Z-cars also use fully trailing, so I guess that's where they got the inspiration. If they are lucky and get it to handle like a mini they will be fine.
I agree it really doesn't look as sturdy as I'd expect (from the picture). Smooth racetrack use only?
MikeRJ - 13/10/05 at 10:10 AM
I agree, horribly flimsy looking. However, you can't clearly see the other part of the trailing arm in that picture. It might be much larger dimater than the diagonal to resist the torsional loads, in which case the diagonal wouldn't be quite as critiical.
Talking of ZCars, I had to wonder at their decision to use a trailing arm rear suspension. It works ok on a standard FWD mini, where the large positive camber that is gained with body roll somewhat compensates for the inherent understeer. However, a fully trailing rear suspension with RWD sounds like a potential recipe for terminal oversteer, especialy with wide, low profile tyres.
Rorty - 13/10/05 at 12:45 PM
I was going to post virtually what you've said, but then I thought maybe it's retaining the FWD Fiesta engine.
Still doesn't excuse those trailing arms though.
I've seen a few Mini grassers that had the rear subframe cut out and an almost identical (though more substantial) looking set-up bolted in and I wondered at the reasoning behind them too. Seemd like a wasted oportunity.
