I installed a Accentra mini control boxes (no pads) and 2 remote keypads.
has been installed for about 5 years and not a problem until tuesday.
For some reason i had a trip on the switch board and lost all power, ever since my alarm has been
not working,
the keypads light up but no power light, no day light, no tamper light nothing apart from the green keys lighting up
i have changed the fuse in the control panel, i have checked that the keypads are getting 13v and they are,
the keypads are front and rear door and both worked up to tuesday, i did have the alarm box flashing but that has stopped now as i reset the system,
but the keypads are dead.
what else should i do apart from change the control panel
Try removing all power and battery for a minute or two. This may reset the system totally. Most modern systems will have NVM so there will, probably be a link on the board that you have to disconnect as well when you do this to reset to factory defaults.
If the power was off for any lenght of time and the backup battery was flat or fooked then the panel has maybe reset to the default factory settings
again (usually 1234 ).
Lsd types quicker than me
[Edited on 1/12/05 by omega 24 v6]
Hi
I would also suggest changing the back up battery if the system has been installed for 5 years, these should be about a tenner from a local electrical
factor. If the system has gone back to factory defaults you will need to reprogramme the zones etc. If you haven't got the installation manual
still then you could try the following link. This is for user manuals but if you call them they may send you an installation manual.
click here
Hope this is of some help.
