hi i put picks in my arcive of my toys ,i gave £100 for chassie is it good or bad
Jock
Did u pay extra for the dirt on the nosecone? seems like a good deal especially if u got the welder and dodgy stereo in the same deal
Shug.
Depends how accurate it is and if you got the bones and shocks as these are all necessary before you weld the brackets on as there are a lot of
variables there!
Pat...
no dust is how long i have had it i am doing a mini first see piks
i just dident no if it was cheep or not i got chass. nose cone .skuttle
hi no i did not get shocks or bones but the chap says it is bilt by the book if the brkts ar not right cant i cut them off and reweld
Caber in Edinburgh and I are in the process of knocking up the Jigs for the bones if u want a set from them, save u the hassle of duplicating the Jigs
needed
Shug.
Hopefully pulling the first set of trailing arms from them today!
Caber
The scuttle appears to have a gap in the middle.
scuttle has been cut in too . because it is short .i can fix i am a caravan repairer at livingston i do this sort of thing every day but is it not
locost rather than big bucks .
You can re-position the suspension brackets if need be. Looks like you got a good deal there. Good Luck.
A one-er for all that seems pretty good to me.
Are those cross-bracing tubes on the sides round by the way?
