what does this look like
Very nice
But what is this weld for?
Very nice![]()
Paul G
[Edited on 3/1/06 by 907]
had to widen bottom rail to get room for starter motor, put weld under engine mount for extra strength.
Thats quick work
Thats quick work
you probably know you're missing on of the braces in the engine bay, are you planning on adding any? Apparently this is one of the twistiest area
of the whole chassis.
Still got to finish braces and rear top of chassis, but just had to get it going, so i put it together. Planning on finishing chassis in next two weeks.
I think you will need a bit of bracing from the top bar that holds the steering column down to the chassis as it will flex as it is.
Pat...
Pat, that's similar to the way I did mine, the column acts as the third point in the system, so very little flex.
Marcus
Mine to, but if I wiggle the wheel up/down, the top bar flexes a bit so I put two braces in place.
Might be better made than mine though
Pat...
