A girl friend has a Corsa 1.2, (early one) and it would appear to be lacking in power. I know its only a 1.2 but it will not pull the skin off a rice
pudding.
No burning oil, no overheating no oil in water and it sounds ok. Plugs changed and air filter.
What are the most likely causes?
being a 1.2?
my gf has a 52 plate 1.2 and to be honest its no race car but i wouldnt say its bad. . .
0-80 is fine, just dont try to overtake more than one car at a time.
does it drive like the chokes on (choke feeling) single point injection??
not really. BTW it wont get to 80 . 70 is hard enough
take it to a local vauxhall garage and give a oily rag a £10 to plug it into there computer shite and see what it says.
i drive a 1.2 s reg corsa and mine does 100mph
all be it down hill with a tail wind!
Alex
italian tune up? lol
[Edited on 16/1/06 by olv]
Check the valve timing , easy job . Someone could have done it wrong if it's been changed . Change the fuel filter . check for full throttle. Try the easy/cheap things first. Brakes binding?
