Anybody fitted one, had a quick look and it appears i need to remove the bumper. Seems a bit over the top. any help would be appreciated. Cheers.
had to remove the bumper on my bora, slotted into the rear subframe of the car easily though.
Ned.
Done towbars on 3 or 4 cars now, and all have required the removal of the bumper. Its actually the worst part as they are usually held on with plastic
clips that are very tricky to get undone.
[Edited on 6/4/06 by flak monkey]
Just fitted a tow bar to my megane had to remove my bumber, initially it looked a pain but turned out to be very easy to do. All job from start to finish about an hour.
how hard is the wiring?! I fancy adding one to the legacy.
yonks ago on a maestro i had to remove the bumper. nothing new there
atb
steve
what towbar have you got shouldnt need removing
have you got laguna 2 or 1?
Cheers for advice. Its an 02 plate. Looks like ive got holes in chassis rails for 1 bolt, and 2 more on rear cross member of chassis, they are not a captivated nut and you cant get behind without moving bumper. Will go and have a go, cheers.
