This is what I've been working on for the past 2 days. It's nearly ready to sail!
Comments?
So far it cost me less than 35 dollars, but I did scavenge the pulleys and most of the lumber from other project bins.
With the pulleys and
additional found lumber, I may have spent a total of 50 bucks.
http://millenniumtree.livejournal.com/19291.html?nc=1
[Edited on 19/4/06 by millenniumtree]
I would have at the very least expected roller reefing and a crusing chute!!!!!
A very cold day off Stonehaven Scotland in the old boat Hurley 22
Nice to see some other water sportsman
[Edited on 19-4-06 by mangogrooveworkshop]
I also plan on making a tug kite for the front passenger to fly when moving downwind. It's easily stowable, and would cost next to nothing.
And of course, there's always the "mary poppins spinnaker"
Do you have a keel?
Here's the family's fibreglass money pit. Hardly locost though!.jpg)
You want to get down to poole! No need for all that clobber, last time i went out was shorts and t-shirt, and that was april.
Lovely weather for it at the moment, much prefer a windsurfing though, more locost and a lot faster!!!
I have a little ridge on the bottom of the canoe, which doesn't really count as a keel, even though it holds that name.
In order to make progress windward with any sort of efficiency, I'll have to install a lee board (possibly two).
Looks like a fun little project. I did something similar to a small rowing dingie as a boy. Istead of lee boards though i fitted two 8" bilge
keels but you wouls struggle with that as its such a noarrow boat. I also used a More traditional Lug rig to maximise sail area.
I reckon yours will be great down wind but you will struggle on a close haul due to the shape of the sail, it needs to be taller with more Luff edge.
Cracking fun though, have you tested it yet?
I went out yesterday with it, and just like you said, it goes like stink downwind (at least twice as fast as it's EVER been paddled), but I
couldn't bring it around to tack.
It's not because of lack of sail though! The wind was blowing something fierce!!
I had messed up the geometry of the boat. Firstly, the front end was light, so the wind was blowing the front downwind anyway... Secondly, the
lee-board was mounted way too far back, so the sail was pushing it even more downwind.
I've now remounted the lee board quite a bit forward to move it closer to the sail's center of effort.
I also drilled 4 mounting holes into the board instead of 1, so it will be at least slightly "field adjustable" I can now control, within a
foot or so, how far back the board will touch the water.
So next time, I'll have the lee further forward, and I'll probably put a weight of some sort (5 gallons of water in jugs should do it) in
the front of the craft, to lessen the bow float effect.
Anyway, because I couldn't tack it back home, and I had no chance of paddling back in that gale, I had to go ashore and WALK home, 1.5 miles! It
took about 10 minutes to sail more than a mile downwind and 40 to walk back. I was pretty tired when I got home, it's hard to believe I was only
actually on the water for an hour or so.
