I need to calculate the buckling load for a vertically mounted hydraulic cylinder in accordance with an agreed formulae from a British Standard.
Trouble is I need the Second Moment of Area of the cylinder rod in 4th power milimetres.
Sounds easy but I'm getting confused.
The cylinder rod is 60mm diameter.
Thanks,
John.
is this any good
Area: 2827.4334
Perimeter: 188.4956
Bounding box: X: -30.0000 -- 30.0000
Y: -30.0000 -- 30.0000
Centroid: X: 0.0000
Y: 0.0000
Moments of inertia: X: 636172.5124
Y: 636172.5124
Product of inertia: XY: 0.0000
Radii of gyration: X: 15.0000
Y: 15.0000
Principal moments and X-Y directions about centroid:
I: 636172.5124 along [0.7071 0.7071]
J: 636172.5124 along [-0.7071 0.7071]
Originally posted by Aboardman
is this any good
Area: 2827.4334
Perimeter: 188.4956
Centroid: X: 0.0000
Y: 0.0000
Y: 636172.5124
Y: 15.0000
some one else has to retake somecourse work then?!
Second moment of area for a solid circular section is (Pi)*(r^4)/4.
Using your diameter of 60mm this gives
Ixx = Iyy = 636200 mm^4
HTH,
Matt.
[Edited on 16/8/06 by matt_claydon]
Ixx = Iyy = 10180000 mm^4
HTH,
Matt.
Yep, thanks for pointing that out - small mistake on my part ; corrected now!
Originally posted by RazMan
You lost me after the word 'calculate'
