do you need a camcorder with AV in to use external cams like the bullet cams ??
Yea unfortunately!! If you go to a company called 4Kam they supply bullet cameras and hard drive recording devices for £200. They supply Motors TV
according to their website-look really good!! Im thinking of getting one after looking into the cost of getting a camera with AV in!!!!
Hi
If you havn't bought a bullit cam yet, this was just reviewed on the gadget show, they set it to record and threw it out the window into the
pond, looked pretty tough
See
http://www.mx1.co.uk/products-ATC2K-Action-Camera_atc2000.htm
Adrian
For recording you really want either a tape based ie mini DV or better a solid state recorder. The hard disk recorders if used on a kit car usually
can't handle the vibations. They'll suffer long term anyway.
My mini DV Sony only works in a fully padded box on our Radical due to the vibrations.
Hi
The ATC2K records directly to a memory card, so no need for a camcorder
Adrian
