Hi All,
I have a bit of a problem, well to be more accurate my brother who was visiting from Belgium has a bit of a problem.
Driving their (old style) mini, it started making rather strange knocking/grinding noise so we started heading back home. Unfortunately shortly after
the nearside front wheel locked. Causing us to need to get recovered to the garage.
This poses a bit of a problem as they are supposed to be heading back home tomorrow but most places dont seem to be open till after new year to look
at it.
My current best guess is something to do with the diff, but does anyone have any better ideas?
Its a bit difficult to test the theory as the car is still at the garage but it would be rather handy to have some idea of what they are dealing
with.
[Edited on 28/12/07 by Duncan_P]
It could be the diff. Some info here. I personaly have never had them fail but it can be a
problem. Other possibilities: CV joint jammed. I have heard of the front brake springs snapping and the shoes locking if it has drums.
Good Luck
Ronnie
Ps. How much do they want for the non running Mini?
Just did a google search and found this West Sussex Mini Owners Club. Maybe somebody there could help you out.
[Edited on 28/12/07 by TGR-ECOSSE]
My 1st thought was diff pin, either that or a shagged g/box but i would say diff.
Thanks, for the info and the pointers I will pass them on
Originally posted by TGR-ECOSSE
Ps. How much do they want for the non running Mini?![]()
I doubt it would be the diff as only the N/S wheel has locked up. Does the car have disc or drum brakes? If drum try letting off the brake adjustors using the correct tool, or try undoing the bleed nipple . If the wheel then turns it is brake related. If the wheel does not turn it may be the wheel bearing failed, might be better to undo the hub nut, the track rod end and the top and bottom ball jonts, pull the drive shaft from the hub then try turning the drive flange. HTH.
The diff is unlikely, it would try to lock both wheels. I've never had it happen to me but I've known a few that have done it & rather
than lock the wheels they generally split the diff casing with a bang & with no warning of the impending disaster.
I'd agree with Rusty Nuts, most likely brake related & more so if it's drum brakes where a lining could come off.
The drums are only held on by two screws when the wheel is off, providing they aint siezed it should be easy to fix if you can get some shoes.
It could be the CV joint but usually you'll get some big vibrations through the steering wheel as the joint jams & trys to steer the wheels
to the angle the joint is jammed at, I've never seen one actually lock the wheel.
Seized wheel cylinder
Had this happen and couldn't believe that it would lock the wheel solid.
Good luck with it. :-)
