cadebytiger
| posted on 8/10/09 at 05:31 PM |
can of petrol vs diesel
I know this is a silly question but i just want to be sure. We have a can of fuel and we are not sure if it is petrol or diesel.
Any acid test? It burns quite sooty and feels greesy so i suspect dirty D but are there any other tests?
Thanks chaps and chapesses
jacko
| posted on 8/10/09 at 05:33 PM |
Derv will not burn without compression
flak monkey
| posted on 8/10/09 at 05:35 PM |
Smells totally different.
Or tip some on a hard surface and leave overnight, if its evaporated its petrol, if not its diesel.
PS - You can drop a lit ciggy into a jar of diesel and it wont go up. Do the same with petrol and you'll lose your eyebrows
[Edited on 8/10/09 by flak monkey]
Sera
http://www.motosera.com
philw
| posted on 8/10/09 at 05:48 PM |
Yes it will, next time you have a bonfire try it.
Must try harder
Mark G
| posted on 8/10/09 at 05:55 PM |
No strictly true, Petrol as a liquid is not flamable. Its only the vapour which is flamable. Drop a match into a can and it'll go out. Hold
one over the fuel and you'll get fire.
owelly
| posted on 8/10/09 at 05:59 PM |
Take a few good strong sniffs. If it makes you happy and giggly, it's petrol. If it gives you nothing more than a grubby nose, it's
diesel.
http://www.ppcmag.co.uk
maartenromijn
| posted on 8/10/09 at 06:31 PM |
Diesel feels greesy if you run it through your fingers. And petrol has a stronger smell.
Every petrolhead should know the difference, right??
BLOG: http://thunderroad-super7.blogspot.com/
MakeEverything
| posted on 8/10/09 at 07:38 PM |
Im not sure the feel would be any different, as they are both oil based, but definitely the smell would give it away.
Kindest Regards,
Richard.
lotusmadandy
| posted on 8/10/09 at 07:54 PM |
They are both oil based but diesel is greasy on your fingers and petrol is not.
Benzine
| posted on 8/10/09 at 08:11 PM |
Diseasil is greasy, petrol dries your skin out.
Or as Ricky from Trailer Park Boys says "Regular tastes sour, premium tastes a little tangy and diesel actually tastes pretty good"
maartenromijn
| posted on 8/10/09 at 08:35 PM |
| posted on 8/10/09 at 08:53 PM |
Errrm?
If you can't remember/don't know what it is, where did you get it/find it?
How much is there?
How old is it likely to be?
unless you're going to lob it in your petrol mower I'd say ditch it (properly at the local recycling place).
ReMan
| posted on 8/10/09 at 09:01 PM |
Just use it for cleaning dirty engine bits with either will do
| posted on 8/10/09 at 10:30 PM |
The smells completely different. Go to the tank of your tintop and have a sniff. Then sniff the can. It'll either smell the same or different.
Only question then is what's in your tintop. But if you don't know that, there's a whole load of other issue more important than
what's in the can
You can tell I drive a DERV car now, a tdi drove past the other day sounding like a whiny tractor and I thought "kwor, that smells
good"!!!! Normally I only think that with un-cat'd RON98
mediabloke
| posted on 8/10/09 at 11:30 PM |
Dip your finger in it. If the smell disappears within an hour, it's petrol. If you can still smell it after a couple of weeks, it must be
diesel...
Danozeman
| posted on 9/10/09 at 06:44 AM |
If its old petrol thats gone off it will smell completley different. A bit like white spririty smell.
Dan
adithorp
| posted on 9/10/09 at 07:34 AM |
If it's greasy and you can light it easily then it could be Parafin.
adrian
http://jpsc.org.uk/forum/
twybrow
| posted on 9/10/09 at 10:53 AM |
I agree - he should sell his Tiger, and donate the money to us, then he should stand in the corner of the room until he has learned his lesson!
Daddylonglegs
| posted on 9/10/09 at 10:57 AM |
put your finger in it.....petrol will degrease your pinky leaving it white and 'orrible, diesel will leave it all greasy and silky smoove!
cadebytiger
| posted on 9/10/09 at 01:54 PM |
Cripes thats a lot of replies!!
The problem was that we just got a new can od dirty D and up it in the garage right next to what we thought was petrol. We then could not remember
which was which and they both looked/smelt/burnt the same.
Turns out that they were both dirty D...
Thanks everyone!
Ninehigh
| posted on 10/10/09 at 10:38 AM |
My bodge advice would have been to fill your car and then chuck it in, at worst it'll feel a bit poo for a while... Provided the cans
aren't that big!
