Author: Subject: tintop number plate
oadamo
posted on 18/10/09 at 11:31 PM Reply With Quote
tintop number plate
hi i have a white bumper and a white bonnet.
could i stick some black numbers on the front of the bonnet or bumper, do you need a black frame thing around the numbers. do you think i could get away with sticking the numbers on the front bumper but its where the intercooler fits so to look at it its flat if you no what i mean.
adam
oh the cars 1995 m reg.
prawnabie
posted on 18/10/09 at 11:33 PM Reply With Quote
Unless your car is reflective id say no.
britishtrident
posted on 19/10/09 at 07:21 AM Reply With Quote
Definite no ---- apart from the high probability of getting stopped number plates are now part of the MOT.
owelly
posted on 19/10/09 at 12:59 PM Reply With Quote
But the MOT doesn't check for the BS number or other such technicalities. See here....
http://www.ukmot.com/6-8.asp#Text_top
Unless the MOT regs have changed.....which they may have...
There are lots of Se7ens with stick-on plates and I know of several that just have the numbers stuck on the nosecone and they pass MOTs and have no bother from the BiB. What usually happens if caught by the BiB is that they give you a 14day wonder (HORT??) to get the vehicle rectified. Unless they deem that you're using the plate to evade arrest, pervert the course of justice etc, etc, in which case they'll have your hoop in a bread bin for it.....
As long as the numbers and letters are correctly fonted, easily readable and look OK. You'll probably be OK. Or not...
[Edited on 19/10/09 by owelly]
http://www.ppcmag.co.uk
britishtrident
posted on 19/10/09 at 07:26 PM Reply With Quote
MOT number plate test requirements changed now.
For cars registered after Sept 1st 2001 Your plate must have
* The new font (79mm high) there are a few excepions motorbikes and some imported cars.
* The name and postcode of the plate supplier
* It must say "BS AU 145d" on it bottom right corner (not neccessarily bottom right but that's where it usually is) - It must also have next to this a small company name or logo (it is the name of the manufacturer of the plate) There are many different types,
mine say HHSP BS AU 145d. The HHSP bit is the manufacturer.
Other examples
"Gould BS AU 145d"
"UP BS AU 145d" etc etc etc
Car registered and used before 2001 have more leeway .
[/I]
