rsmith95uk
| posted on 6/8/10 at 09:31 AM |
Cutting Kitchen Worksurface
Hi,
will be putting in new worksurfaces shortly and a change in design means that I will now have an external 90 degree turn.
My question is, how do you mitre these so that you get a bevelled edge around the turn? I have assumed that the only way to do it is to cut each
'board' at 45 degrees, but I'm not confident that I could get a perfect fit, especially as I expect the walls will not be perfectly
at that angle!
OR
Shall I leave it to a professional - if so, any recommendations in the Romford/Hornchurch area?
Ray
blakep82
| posted on 6/8/10 at 09:35 AM |
i think you can buy a sort of template thing that shows you all the best ways to cut corners on worktops?
________________________
rsmith95uk
| posted on 6/8/10 at 09:40 AM |
These appear to only cater for internal mitre's, although I'm prepared to be proved wrong!
adithorp
| posted on 6/8/10 at 09:48 AM |
Not sure about the best way of mitering it but a friend of mine says always use a new blade for each cut. Otherwise although the blade might be
following the line at the top by the jigsaw, it'll bend/waver below. He also uses down cut blades in his jig saw so he cuts from the top surface
without chiping it. Down cut blades do need you to keep presure on the jigsaw at all times though.
http://jpsc.org.uk/forum/
Liam
Aye 45 degrees and they should match up. Or more generally - half the total angle each and the profile will match up. Having said that, if the
deviation is very small on your not quite 90 degree walls (they never are), even if you cut one at 45 degrees and the other ended up having to be cut
at 43, say, the difference in the profile will be so small they'll match up pretty well.
thunderace
| posted on 6/8/10 at 10:39 AM |
unless your a kitchin fitter dont bother as you need a jig and a router,(about £400)
just buy joining strips its the easy way and gives a nice finish .
like this
http://cgi.ebay.co.uk/40MM-WORKTOP-CORNER-JOINING-STRIP-BLACK-/300286923731?cmd=ViewItem&pt=UK_Kitchen_Accessories&hash=item45ea7ed3d3
as for cuting the sink get a worktop cutting blade for your jigsaw as it wont chip as bad and cuts on the down stroke
and i always use 2" masking tape it good to see your lines and stops the fence on the jigsaw marking the worktop and can help stoping it chip.
thunderace
| posted on 6/8/10 at 10:42 AM |
did not spot it was an external 90 degree turn.
MikeR
| posted on 6/8/10 at 12:04 PM |
internal 90 - use a joining strip.
External 90 - use a professional.
When i cut mine i used a circular saw with expensive, many toothed blade. To cut out the sink i used the router as i didnt trust the jig saw blade not
too cut perfectly vertically
| posted on 6/8/10 at 12:11 PM |
No it doesn't!
Jig costs £20
Router costs £40
Kitchen worktop bit kit £10
(I bought them all for my kitchen installation). My old router had two narrow a collett for the length of bits needed.
Trouble is the skill bit is priceless
Liam
| posted on 6/8/10 at 12:37 PM |
Not that I've done any, but I don't see why an external mitre should be so much more difficult than an internal mitre that people are
saying use a pro??
Of course dont use a jigsaw as the best jigsaw blade in the world on the best jigsaw in the world guided by a straight-edge will still wander through
40mm of worktop. So just mark up, clamp a straight-edge on and use a router for the cut. Can't see why it should be any more difficult than a
hockey-stick internal mitre.
locogeoff
| posted on 6/8/10 at 12:41 PM |
No it doesn't!
Jig costs £20
Router costs £40
I'll second that, and got excellent results from one up from cheapest B&Q sourced tools, a decent jig properly clamped and sharp router bits
removes a great deal of the skill required.
p.s. I'd say the router I bought as a "I'm only going to use this once but" has been the most usefull piece of kit I've
ever bought under those conditions, I made jigs for a belfast sink cutout, and when cutting worktops it's just a case of hack off more than you
need by a couple of mm then router back to the exact length for a good finish. Woudn't even think about cutting a worktop without one these
days.
On the other hand I don't think an external mitre would be possible with a masons mitre, but the router will give you a nice neat cut.
Personally I'd make the worktops join at right angles then fit the kitchen to the worktop by fettling the edge of the worktop or the wall until
it fits nice, but thats just me
| posted on 6/8/10 at 12:51 PM |
Where's Joelp, he'll put you right.
interestedparty
| posted on 6/8/10 at 01:03 PM |
The only way to get a clean joining edge is with a router, and you really want a big (1/2 inch) one for that job. Then you need to guide it in a dead
straight line (otherwise there will be gaps in the join).
One of the pieces will have to be turned upside down for the trimming cut (routers only work one way).
The better a cut you get, the more noticeable any imperfections will be.
There is NO WAY you will do an adequate job on your first attempt.
[Edited on 6/8/10 by interestedparty]
As some day it may happen that a victim must be found,
I've got a little list-- I've got a little list
Of society offenders who might well be underground,
And who never would be missed-- who never would be missed!
gottabedone
| posted on 6/8/10 at 03:59 PM |
Screwfix is your friend here - it's not too dificult
v8kid
| posted on 6/8/10 at 04:09 PM |
Done hundreds of kitchens in my time and always subbie worktop mitering out.
£40 to £50 is the going rate.
Professional templates cost hundreds and you need a big router with a v sharp bit - not a cheapo one cos they blunt before the first cut is
finished.
The difference is immediately apparent. Why spoil your all your hard work for the sake of a few pounds?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
interestedparty
| posted on 6/8/10 at 04:26 PM |
As long as you don't care what the finished job looks like.
zilspeed
| posted on 6/8/10 at 05:36 PM |
If you know what you're doing, you can achieve a completely satisfactory result with nothing more complicated than £6 worth of Sandvik 244.
And when I say completely satisfactory, I mean a pukka mason's mitre with no gaps in it.
Yes, the jig and router make it simpler to acheive consistently good results, but it's just a cut at the end of the day.
| posted on 6/8/10 at 05:56 PM |
dead easy with a router, cut the left one first at 45 degrees, then sit the other on top and mark it up, flip it over and cut it.
Have you thought about the nasty pointy sharp corner you will be left with? Probably wants a few inches taking off it, and edging. Not entirely
straight forward that bit as you would have to cut it before its joined, as the exit wound would ruin your bullnose.
mark.s
| posted on 6/8/10 at 06:41 PM |
its not worth the hassle doing it your self, you have got to get a router, jig, work top bolts, colour fill (if you want to use it)
i'm sure you've got the glue and 10mm spanner for the bolts
then...
you've got the pressure of fitting it and making it look good, get it wrong and your spending even more money
ring a fitter defo
mark
interestedparty
| posted on 6/8/10 at 06:42 PM |
Whether its easy or difficult for those people who have done this stuff before, I stand by what I said earlier and repeat that there is no way someone
who hasn't done anything like this before is going to get an acceptable result on his first attempt.
