tony-devon
| posted on 13/9/10 at 10:04 AM |
CAD software
I am heavily into RC models of all sorts and recently decided that I would like to make the leap into making more bits myself and ideally the easy way
I have seen CNC engraver/routers etc online, but my biggest hurdle is that I have never done anywork with CAD software
SO....
is it that hard that I shouldnt bother? or can you teach an old dog new tricks
Im looking for a suitable ideally fairly simple and cheap piece of software to start out with, initially I want to be able to draw up my parts and
then take the file to a local engineering company to get them to cut it out for me, so I can see if I have got it right, and also to just get me into
the swing of it
do any of the programmes actually allow you to "see" what you will produce with that drawing, so at least I can see if it looks right LOL,
back in college I did some CNC programming, and more than once right at the last minute the tool would run right across the job LOL, this was very
simple shapes etc, you programmed the machine, not via a computer?
I would also prefer it if the software was a popular one, ie probably able to get a dummies guide book for it
work initially will be limited to just routing out from sheets of 2mm, 3mm carbon fibre
I got a full version of dreamweaver years back and after playing with it and reading a few books etc I produced a few good working websites with
frames etc, so Im not a total idiot, just about 97% there, but Im working on finding that last 5%
[Edited on 13/9/10 by tony-devon]
heavy is good, heavy is reliable, and if it breaks, hit them with it
nitram38
| posted on 13/9/10 at 10:07 AM |
Solidworks is a good program as it lets you connect parts and move them about even in 3D.
The downside is the cost, unless you can download a torrent copy (I'm not suggesting you do this! )
eddie99
| posted on 13/9/10 at 10:10 AM |
Another vote for solidworks, if you put in the time and effort and want to do it... Then im pretty sure anyone can get decent on solidworks!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
balidey
| posted on 13/9/10 at 10:25 AM |
I use SolidWorks, have done for over 11 years now. Its bloody fantastic. BUT and its a big but. For what you want to do its overkill. Making parts for
your own RC car? Well then a sheet of CF and a dremel will be perfect. Draw what you want on good paper and cut round it.
I can justify the 8 grand cost of SW as the vehicles I design are about £20,000 plus.
Also, using 3D cad is one thing, then getting the file output onto a CNC machine is another big step. Personally I wouldn't bother. Thats not
saying don't learn CAD, just not for making some model parts.
Hope you see my point there?
Dutch bears have terrible skin due to their clogged paws
balidey
| posted on 13/9/10 at 10:26 AM |
Also, if you do go this route then you don't need 3D CAD. Routing uses 2D profiles, so any of the free 2D cad packages will be all you need.
tony-devon
| posted on 13/9/10 at 10:44 AM |
Hi yes thanks for the advice, you are of course correct, I only need 2D, 3D would be great but well beyond my understanding
I often make parts and then want to change it slightly, or mates see it and want one etc, the ability to change it, then make one from cheap acrylic
sheet to check for geometry and physical fit etc would be great
oh and of course, its a gadget
will find some 2d cad software and have a play then
my naive understanding was that with the correct software I could draw the part, then it would do the "coding" bit for having it cut
out.
thanks for taking the time to trply guys, I need to think it through a little more and have a play with some software methinks!
iank
| posted on 13/9/10 at 10:49 AM |
I use Q-cad for 2D work. It's very cheap (£25) but capable enough and you can get a book. Produces dxf files which everyone will be able to
use.
http://www.ribbonsoft.com/qcad.html
Anonymous
wescottishmatt
| posted on 13/9/10 at 11:39 AM |
Another vote for the 3D solidworks but if its just 2D you're after try the freebie downlaod 'DraftSight' from the Solidworks
website. (Very similar to the older Autocad software)
Have a look in my Photo Archive. There's a few Solidworks images I did before I began the real build. Did it for the colour options and
decals.
[Edited on 13/9/10 by wescottishmatt]
brianthemagical
| posted on 13/9/10 at 11:44 AM |
By the sounds of it, one reason you want to use CAD is because you can, in which case i'd be looking at 3D. It is pretty cool when drawing 3D
parts. Even if it's just a 3m plate. You can then produce a 2D drawing, print it to scale and trace around it. If they're simple parts
then you may even be able to take it to someone who can manually input it into a CNC machine, or manually cut it.
It is possible to produce the commands for CNC from CAD files, you may need an add-in or, maybe just save it as a DXF.
Another vote for SW, you'll have to find somewhere to download it though.
trextr7monkey
| posted on 13/9/10 at 02:31 PM |
Roland produce some 3d software which by modern standards is very clunky but it is easyto operate and it does work with their machines- think of it as
deep engraving, have a look on their webside for 3d design , they also do a 2d design programme (aptly called 2 d design )which is handy for vinyl
cutting
hope this helps
Mike
Mix
| posted on 13/9/10 at 04:06 PM |
Hi
I've been using TurboCad for a few years now as a hobby - used it for the ongoing Locost and for numerous woodturning / work projects. Fairly
easy to get to grips with and very good value, IMO, when compared to the professional packages. You can get the Deluxe version 14 with a training DVD
from Amazon for £23 at the moment. Exports to all the normal formats.
Regards Mick
Forgot to say you can download free 30 day trial versions from the Avanquest website.
[Edited on 13/9/10 by Mix]
tony-devon
| posted on 13/9/10 at 04:31 PM |
thanks, made a note of all them programmes and will look into them
