MikeR
| posted on 20/12/10 at 04:29 PM |
Need roof advice, steel flue, condensation on precast flue
Arrgghh!
G/f noticed this morning a bit of damp in the bedroom. Turns out at the top of the precast flue there is damp along its top edge and a cm down the
sides. Spent ages but got into the attic and able to get to the flue. The steel flue that goes through the roof isn't connected to the precast
flue in the wall!!! :O Have found a number of bits of concrete and a broken bit of tile all around the flue
Luckily i've not used the flue in 4 or 5 years, removed the fire and plasterboarded over the fire place.
So ........ how does the metal flue go through the roof? Tried moving it to get it into the precast flue. I can move the whole flue but not the inner
metal pipe - possibly due to the roof been really shallow slope and i can only just get a hand to it. Can't get at it from the outside due to
nextdoors house being litterally 6" from mine
Can't prove anything but this may have happened when the blokes who did my guttering were moving the tiles. No idea at the moment how water
proof the roof is.
Suggestions?
I'm thinking of putting some plasticy closed cell foam between the metal and concrete bits of flue - hopefully stop any water running down (if
thats a problem) as a temporary measure.
(edited to add, managed to get a small bit of wood between the flue and a batton next to it - the flue is now pretty much vertical. Got the roofer who
did the work coming back tomorrow to reseat the vent - curious how he'll do it, but thats his problem).
[Edited on 20/12/10 by MikeR]
Puzzled
| posted on 20/12/10 at 07:28 PM |
flue
Love to B able to help but dont understand one word of what you are saying!!!!!."A picture paints a thousand words" Hope you get it
sorted.
| posted on 20/12/10 at 11:04 PM |
If you've sealed it at the bottom it should really have a vent in it or it can get damp in the chimney. If you don't intend to use it at
any time have it removed and the hole in the roof tiled over.
MikeR
| posted on 20/12/10 at 11:09 PM |
Very tempted with that option - reality is it just needs the flue removing from the top then it becomes part of the cavity wall ..... something for
the summer when i get a roofer in to look why two of the joists seems to have a permanent wet stain down them from the top of the roof.
Got the bloke who did the gutters / facias coming round tomorrow. He can't understand why there's a problem with the condensation (another
story) but didn't bad an eye lid about the flue & said he go up the ladder and sort it. Suspect he'll change his mind when he
see's how little room he has to work in - but thats his problem.
