Author: Subject: Colin would be proud
Alan B
posted on 15/4/11 at 06:59 PM Reply With Quote
I just did a revision to a part at work.....reduced it's weight from 2.145 pounds down to 0.872 pounds.
Revision description says.....
"added lightness"
clairetoo
posted on 15/4/11 at 07:02 PM Reply With Quote
Where can I get some of this magical `lightness' - I could use some (oh , and some for the Fury if I can get enough )
And well done - sounds like a result
Its cuz I is blond , innit
Claire xx
Will weld for food......
TimC
posted on 15/4/11 at 07:10 PM Reply With Quote
You live in Florida. I assume it was a boob reduction job.
beagley
posted on 15/4/11 at 07:11 PM Reply With Quote
If my math is correct that is a 99.96% reduction in weight. Top notch Alan!
Beags
I'm not scared!!! I'm just marking my territory.
beagley
posted on 15/4/11 at 07:12 PM Reply With Quote
Pfff.... there aren't very many reductions going on here, not that I'm complaining about it.
Beags
MikeRJ
posted on 15/4/11 at 07:30 PM Reply With Quote
Beags
It's a tad under 60%, but still impressive. Unless material spec was simply changed from depleted uranium to titanium
beagley
posted on 15/4/11 at 07:32 PM Reply With Quote
Beags
Unobtainum or Nonexistium even
Man..... my math isn't what it used to be I guess. Just checked it again and it is a 59.35% reduction in weight. As said, very impressive.
posted on 15/4/11 at 07:42 PM Reply With Quote
What did you do Alan, throw it in the bin and keep the wrapper?
britishtrident
posted on 15/4/11 at 08:31 PM Reply With Quote
At the start of WW2 Wiilys had trouble meeting the US Quartermaster General's specification for the original "Truck 1/4 Ton 4x4" Jeep they took as much weight out of everything they could, the final documentation read;
Weight xxxx pounds (Paint Sprayed Thin)
steve m
posted on 16/4/11 at 03:41 AM Reply With Quote
One of my winter jobs, on the 7, was to cut off any bolt that had more than a couple of threads showing, above the nut
I also have removed the spare wheel, and related braketry to attach to the back panel, as it was pointless having the thing there, plus the tyre was flat anyway
also a new (to me) caterham roll bar installed, that weighed a third of my old one
Now only one fog light, not two
and all the other little bits and piece's that are not really required
I have saved a total of 49lbs
My next mission is some LIGHT wheels, and slightley narrower tyres, so in theory could save another 20lbs as my current 2.8 capri units and tyres weigh a bloody ton
and i still weigh the same as 10 years ago, so i am not on a diet
