Author: Subject: Replacing old style "Domino" fuses
russbost
posted on 3/8/16 at 08:34 AM Reply With Quote
I have an old style fuse box in the garage which I want to replace the fuses (by domino style I mean the big bulky things with spots on to identify lighting/power etc with white red or blue spots) with circuit breakers, so I can isolate a circuit without having to pull a fuse. They are a blade type fitting which slide in & out of the front of the panel
What is the correct name/type for what I need to fit, there seem to be loads of different types - MCB, Wylex, Mini, Type B etc etc, I don't want to buy something that won't fit!
Smoking Frog
posted on 3/8/16 at 08:47 AM Reply With Quote
These are the sort you need. No electrician mind!
http://www.screwfix.com/p/wylex-40a-sp-type-b-curve-mcb/77992?kpid=77992&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20trac king%20url&gclid=CjwKEAjwrIa9BRD5_dvqqazMrFESJACdv27GW9Z3_VD80jaUR2MhSMdFRvFQwGdbTzAMyr5lbrLL9xoCUT_w_wcB
russbost
posted on 3/8/16 at 08:50 AM Reply With Quote
So are the important words Wylex & MCB for standard consumer units? I assume the type B curve is referring to the way the circuit breaker will define when it should break the current?
Smoking Frog
posted on 3/8/16 at 10:03 AM Reply With Quote
Sorry can't help you any further. I remember looking into this several years ago and this was the type I needed to replace the fuse wire type in my consumer unit. If you go to B&Q they have these and others with information on the package which may help.
gremlin1234
posted on 3/8/16 at 10:38 AM Reply With Quote
this youtube vid may help.
though it suggests its not worth doing, (but as you want to isolate the circuit easily may be worth doing)
[Edited on 3/8/16 by gremlin1234]
russbost
posted on 3/8/16 at 04:53 PM Reply With Quote
Thanks for info!
posted on 3/8/16 at 07:53 PM Reply With Quote
If you go into an electrical wholesalers and ask for plug-in mcbs to replace rewireable fuses, you'll get the right thing. B-type does indeed relate to how it trips.
It would be a better installation though if you had an rcd somewhere.
