Author: Subject: Changing a sink...
Northy
posted on 30/1/05 at 01:43 PM Reply With Quote
Changing a sink...
Todays task is changing the sink and tap. I'm happy with that part of it, but just wondered if I should turn anything off before I drain the water out of the hot water tank? I can't see a switch anywhere....
Graham
stevebubs
posted on 30/1/05 at 03:00 PM Reply With Quote
Central heating. If you can't find the switch, pull the fuse.
zilspeed
posted on 30/1/05 at 03:04 PM Reply With Quote
Turn the cold supply off at the rising main.
The cold water supply yo the sink will be coming direct from there if it's the kitchen sink
Northy
posted on 30/1/05 at 03:21 PM Reply With Quote
Cheers guys, done the water bit now but the sink's dented Should have checked it before I started. Our lass now has to race to B&Q before they shut or I'll have to fit the old one back in!
Graham
stevebubs
posted on 30/1/05 at 03:58 PM Reply With Quote
Bit late now but whenever I fit new tings like sinks, I always plumb in one of the inline valves so if anything is wrong I can turn the water back on quite quickly without affecting the rest of the house.
You can use the ones with large red/blue taps or there is a more discrete version which you need a flat-bladed screwdriver to operate.
S
posted on 30/1/05 at 09:25 PM Reply With Quote
Did you get the radiator shifted?
Northy
posted on 30/1/05 at 09:43 PM Reply With Quote
Not today, still doing the twating sink!
Graham
RoadkillUK
posted on 31/1/05 at 03:07 AM Reply With Quote
I've got a full bathroom to do in a couple of weeks and I'm preparing myself with How-To's.
I've found Homebase useful.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 31/1/05 at 08:38 AM Reply With Quote
http://www.diydoctor.org.uk/projects.htm
one of my favourite links!
posted on 31/1/05 at 10:21 AM Reply With Quote
Screwfix
They have a talk section on the site where you can post messages and tips.
http://www.screwfix.com/talk/index.jspa?forumTab=forums&ts=66760
