Author: Subject: Stove enamelling
Browser
posted on 20/6/05 at 07:43 PM Reply With Quote
Stove enamelling
Could those more enlightened than I read the following and see whether I am (as usual) talking cobblers.
My gas BBQ was finished with a less than durable coating which is falling off, added to which it is crackle-textured and a bu^^er to clean. I want to get a durable, heat-resistant finish put on it and was thinking stove enamel would do the trick. Now, am I right in thinking that stove enamel is the finish used on the inside of domestic ovens, or is this summat different? Whatever I get put on I want to be as easy to clean as possible.
Answers on a postcard to: "Browsers Clueless Again competition, The Village Pillory, Crowland, Lincs".
P.S. subject to confirmation that this or another suggested process will be OK for what I want, if anybody can get me a 'back door' job done I would be exceedingly grateful
simonH
posted on 20/6/05 at 08:00 PM Reply With Quote
nope
stive enamel is the finish on the outside of an old oven . it is a durable white enamel. this is normally a glass type substance that is applied as a powder and heated. it produces a smoth durable finish, very simmilar to the inside of an enamled bath
Never be afraid to try something new. Remember that a lone amateur built the Ark. A large group of professionals built the Titanic.
posted on 20/6/05 at 08:36 PM Reply With Quote
steady on love, thats solicitation!
DavidM
posted on 20/6/05 at 08:55 PM Reply With Quote
The finish on the inside of ovens is Vitreous Enamel. This is a type of glass finish fused to the steel at temperatures of around 800 degrees C.
I used to worked in the Vitreous Enamelling industry up until 3 years ago. Sadly there are very few companies in the UK now applying this finish, with most of the work now being produced in Eastern Europe and the Far East.
Typically the finish from a UK enameller would be £60 to £80 per square metre.
Powder Coating as used on most cooker doors and many kit car chassis will not withstand the heat of a Barbeque.
Proportion is Everything
Andrew+dad
posted on 20/6/05 at 09:03 PM Reply With Quote
if you want to talk about metal coatings then u shud talk to my dad u need to be abvle to tell him to shut up when hes rambling tho or u will be sitting there for ever
he is a metalurgist and can probly direct you to a company and tlel u wot to ask for .... ill speak to him in the morning
steve_gus
posted on 20/6/05 at 10:39 PM Reply With Quote
there is a place in wellingborough that does 'stove enammelling' and i visited it about 10 years ago.
its not a process that can be done at home - as had been said, its a high temperature powder coat process that melts a silica coating onto the metal.
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
Browser
posted on 21/6/05 at 02:59 PM Reply With Quote
Cheers bud, I'll await an answer (if there is one)
