Author: Subject: Conversion from lbs/in to N/mm
Northy
posted on 19/10/05 at 09:29 PM Reply With Quote
Does anyone know how to convert from lbs/in to N/mm?
G
Graham
slim Jim
posted on 19/10/05 at 09:35 PM Reply With Quote
I believe you.....
multiply Pounds per square inch x 0.006895 to convert to
Newton meters per square mm.
rayward
posted on 19/10/05 at 10:38 PM Reply With Quote
you have email.
Ray
stevebubs
posted on 19/10/05 at 11:25 PM Reply With Quote
Google Calculator
Type 1lb/in to N/mm into google
http://www.google.co.uk/search?hl=en&q=1lbs%2 Fin+to+N%2Fmm&btnG=Google+Search&meta=
[Edited on 19/10/05 by stevebubs]
BKLOCO
posted on 20/10/05 at 04:23 AM Reply With Quote
here,s another one.....
http://www.onlineconversion.com/torque.htm
matt_claydon
posted on 20/10/05 at 07:42 AM Reply With Quote
Be careful, there's a world of difference between a pound per inch (spring rate) and a pound-inch (torque)!
posted on 20/10/05 at 06:12 PM Reply With Quote
Buy a torque wrench with both scales? Some of the older Haynes manuals used to have a conversion chart.
Mix
posted on 22/10/05 at 08:54 AM Reply With Quote
There is a very good freeware program called 'Convert'. I keep it on the desktop of all the computers I use, very useful.
Mick
http://www.joshmadison.com/software/convert/
[Edited on 22/10/05 by Mix]
steve_gus
posted on 22/10/05 at 11:28 AM Reply With Quote
google does it fine
1 pounds force / in = 0.175126835 newtons / millimeter
http://www.locostbuilder.co.uk
Just knock off the 's'!
