bigbriglasgow
| posted on 12/1/06 at 04:01 PM |
New corsa washer problem
Hi All got a 51 plate corsa and the washers have packed in
pull the thingy and there is no power going to the pump. wipers move ok but no water comes out!!
pump ok as tested with a direct feed and fuse seems ok too!!!
Help which relay as it does not tell you in the book!!!!
cheers
Brian
coz its a bit of an animal
Mr G
| posted on 12/1/06 at 05:21 PM |
No previous experience of this model etc but are you sure its relayed? Most squirts work by giving a direct feed via the stalks.
Sorry I can't be more specific and i'm sure someone with a haynes will be along at some point
G
oliwb
| posted on 12/1/06 at 05:27 PM |
yeh would have thought there'd be no relay aswell....could be wrong though...Oli.
