Author: Subject: Knock sensors (GM X18XE)
NigeEss
posted on 23/9/09 at 11:32 PM Reply With Quote
Friend of mine has a '99 Vectra which is running like a bag of poo.
Diagnostics said knock sensor faults on cylinders 1,2,3 and 4.
However I didn't realise these engines had knock sensors and I'm buggered if I can find
one let alone four !
So is this function carried out by another sensor, eg crank or has the ecu lost the plot ??
RK
posted on 24/9/09 at 03:47 AM Reply With Quote
Speaking of knock sensors, I have a wire coming off the engine sensor, labelled as such, that right now, goes precisely NOWHERE. Is it important? I seriously don't have any idea what it's for.
[Edited on 24/9/09 by RK]
Ben_Copeland
posted on 24/9/09 at 05:30 AM Reply With Quote
I know the C2.0XE knock sensor is in the bottom end, pointing at the crank.
Have you tried looking around the bottom end for it?
The cables could of come off or got pulled off. Hence the fault codes.
Ben
Locost Map on Google Maps
Enter Your Details Here
bigrich
posted on 24/9/09 at 07:52 AM Reply With Quote
usually found in the centre of the back side of the block, just a single sensor.
MakeEverything
posted on 24/9/09 at 12:45 PM Reply With Quote
^^ Ditto.
The knock sensor will identify the cylinder by the angle of the crank and relevant subsequent ignition angle.
Kindest Regards,
Richard.
MakeEverything
posted on 24/9/09 at 12:56 PM Reply With Quote
Originally posted by MakeEverything
^^ Ditto.
Or rather the ECU will do that for it...
Kindest Regards,
Richard.
