<<  1    2  >>
Author: Subject: Networking a house
posted on 31/10/09 at 01:26 PM Reply With Quote
Networking a house
I'm starting a house renovation in a couple of weeks time (contracts willing!).
Everyone keeps on yabbering on about putting in Cat5 whilst I'm doing the re-wire but being a network noob what's the plan? Previously I haven't done anything more complicated than wiring up cable modem to a wifi router
I don't want to go crazy with six cables going to each room etc etc so what does anyone reckon about a cat5 cable going to a wall plate in each room back to my existing cable router?
I'm thinking of using something like this
http://www.screwfix.com/prods/10346/Electrical-Supplies/Data-Networking/Cable/Network-Cabling-Kit
Is it worth putting a couple of cables to each room? I know people talk about IP phones and networking tv blah blah blah but realistically I'm going to be using this mainly for HD iplayer....
Staple balls
posted on 31/10/09 at 01:32 PM Reply With Quote
Use decent quality cable, and run 2 to each room, even if you only intend to use one. The last thing you want to do is find a cable died some time between installing and decorating.
Also, I seem to remember 30cm from mains power is suggested, but I've not done this stuff in years.
big-vee-twin
posted on 31/10/09 at 01:47 PM Reply With Quote
Why not just use WI-FI just as good
http://www.triangleltd.com
Guinness
posted on 31/10/09 at 01:50 PM Reply With Quote
I've done the ground floor of our house. Still got the first floor to do. Basically we had the floorboards / skirting boards off anyway, so I fitted a 10 way switch in the understairs cupboard. From there, I connected via a set of ethernet cables down to a pair of twin outlet RJ45 sockets. From there, there are a pair of cables into the dining room and another pair into the lounge.
Next up will be a pair of cables into each bedroom.
I've got a few hundred metres of cable left over Ben, so if you want a reel, and are willing to cover the postage, you can have a few hundred metres for free. The reels weigh between 11kg and 8kg, depending on how much cable is left on them.
Mike
mark chandler
posted on 31/10/09 at 01:51 PM Reply With Quote
Easier route is just WIFI, you can also get ethernet over the mains wiring as well these days, still if they are paying...
tegwin
posted on 31/10/09 at 01:52 PM Reply With Quote
Rubbish... WIFI wont run at 1000 mb/s! or even 100 usually!
I would be looking at putting in Cat 6 cable!! (cat 5 is old hat!)
I did our house when we moved in and just used ready made cables, so we dont have nice sockets on the walls.. we just have bits of cable hanging out with the connector on the end...
If I were doing it again, run two lengths of cat6 cables to each room (buy a box reel.. its not that expensive!)
Bundle the cables ideally away from the power cables etc.
Where all the cables terminate in your cupboard... either crimp the cable ends onto a patch pannel, or fit plugs on the end and plug them straight into your switch... depends how much of a stickler you are for "perfect wiring" :p
www.verticalhorizonsmedia.tv
blakep82
posted on 31/10/09 at 01:56 PM Reply With Quote
mmm cable broadband in every room
you can get things that you plug into a normal electric socket. router goes into one, computer plugs into the other, and it just goes in another socket, internet goes through the normal electic cables. strange but true
like this
http://www.broadband-mac.co.uk/mains_networking.htm
[Edited on 31/10/09 by blakep82]
________________________
It's me paying
Guiness- yes please!! Consider any postage + VAT covered.....
Staple balls
posted on 31/10/09 at 01:57 PM Reply With Quote
At least Cat5e for my money, cat6 is more fun though and not one of those £30 for 1000' reels, utterly crap cable.
tegwin
posted on 31/10/09 at 01:59 PM Reply With Quote
RS components do a 100m reel for about £60 I think... that looks reasonable...
Anyone ever seen a cat 6 patch panel with less than 24 ports on it? I cant find one anywhere :p
Jasper
posted on 31/10/09 at 02:08 PM Reply With Quote
When we had the ground floor rewired we had the electrician put in CAT5 from the office to the lounge, didn't cost much extra as he was already running standard wires.
stevebubs
posted on 31/10/09 at 02:09 PM Reply With Quote
http://www.cablemanstore.co.uk/#111436X0
stevebubs
posted on 31/10/09 at 02:13 PM Reply With Quote
Run a couple of ports to each room.
a) If a cable dies then you're covered
b) If you decide you want to pump something non-ethernet over the second cable, then you can do...
Stephen
PS New Wireless 802.11n routers are 350Mbit/s ... how well they work depends on the density of housing around you...
1) Think walls - not good
2) Lots of neightbours - not good.
Bear in mind that there are only really 3 channels that don't overlap - the normal ones quoted are 1,6,11 but 1,7,13 are better (the former are US channels which don't extend quite as far up the spectrum)
S
Jasper
posted on 31/10/09 at 02:27 PM Reply With Quote
I use Popcorn Hour to watch movies from my PC HDD through into the lounge and onto my plasma, you couldn't do this with High Def films via wireless, it has to be a solid connection.
jeffw
posted on 31/10/09 at 02:30 PM Reply With Quote
There is no way that you will ever get 350Mb/s out of 802.11n, not happening.
1Gb/s over Cat5e is easy and relatively cheap...plus it is secure. My day job is IT security and I don't run wireless unless there is a full on IPSec VPN client involved. If you don't want everyone else knowing your business buy a decent UTM device and wire your network.
Guinness
posted on 31/10/09 at 03:34 PM Reply With Quote
Originally posted by BenB
It's me paying
Ben, u2u me your address, and I'll get a reel in the post to you on Monday (will try to beat the postal strikes).
Mike
Ben_Copeland
posted on 31/10/09 at 04:44 PM Reply With Quote
I wired a line from my router down to the living room. Linking 2 computers and the LCD.
Run a 1Gb network and it'll play anything smootly over the network.
Copying films across is easy, couple minutes. Wifi either drops its connection or just take hours to copy. Rubbish
Ben
Locost Map on Google Maps
Enter Your Details Here
D Beddows
posted on 31/10/09 at 05:24 PM Reply With Quote
I had cat5 cables put in when we moved to our present house and were having some other wiring done - one of the best things I had done tbh! Not having to p*ss about configuring wireless routers is a godsend - you just plug the ethernet cable into the socket and bingo, reliable broadband speeds and connection etc etc anywhere in the house
[Edited on 31/10/09 by D Beddows]
keithice
posted on 31/10/09 at 05:44 PM Reply With Quote
when the floorboards were up I bought an ethernet cable from the frontroom to where the computer would be in the dining room, another up to my boys bedroom. virgin socket to router then split to here and up to his room. his laptop had wireless... I don't need cable dad it's old fashioned .... try it says I... he never said anything about it but it's always plugged in ..
Smile and wave boys.... Smile and wave....
Werner Van Loock
posted on 31/10/09 at 07:22 PM Reply With Quote
If you don't intend to use gigabit, then you can run 2 wall sockets from 1 cable as only 4 of the 8 wires of the cable are needed.
So what you do is wire one plug with the regular orange/white, orange, green/white, nothing, nothing, green, 2x nothing
and the other with blue/white, blue, brown/white, nothing, nothing, brown, 2x nothing.
This is the real locost style
http://www.clubstylus.be
posted on 31/10/09 at 08:18 PM Reply With Quote
Doesn't that mean you're running without screens??
Guinness
posted on 31/10/09 at 08:34 PM Reply With Quote
Most CAT5e cable isn't screened. You can get CAT5E with a foil to act as a screen.
The 2 for 1 by using alternate pairs for separate sockets is a bit of a dodge, but not unknown when the cost of installing another cable is prohibitive.
Mike
posted on 31/10/09 at 11:06 PM Reply With Quote
Luckily I've got some nice cheap Cat5 cable heading my way so the cost ain't a problem any more
wilkingj
posted on 1/11/09 at 11:15 AM Reply With Quote
Please DO NOT use LAN over the Mains Wiring
PLEASE DO NOT consider Ethernet over the Mains devices.
Whilst these do work well. Electrically they are very very nasty in that they radiate high levels of interference and interfere with other radio services.
There is an ongoing battle with Offcomm over this technology raging at the moment.
http://www.southgatearc.org/news/september2009/rsgb_legal_challenge_to_plt.htm
If you can get cables under the floor, thats the best way to go. Its a WIN-WIn solution.
You GET NO interference, and you GIVE NO interference!
I agree with CAT6 (5/5e is old hat now)
for some futureproofing.
Run 2 cables. The cost is only in the cable, and the hassle of having to run another one is not fun once all the floorboards / ceilings are up. ie Do it once, and do it right first time.
I would have my router at the Master Phone Line socket. (Best position)
I would ensure I have the latest Master socket (Your Phone provider does this not you, and will probably charge to change it!), and then fit an I-Plate which will help with the broadband speeds.
For the technical types, the I-Plate puts a choke / Inductor in the bell wire circuit, which reduces interference and losses, thus increasing the speed. However you must have the correct type of Master socket to fit the plate.
Thus you have your ADSL Router located at the master socket, and then run all your cables back to this point. Then depending on how many PC's you are connecting to the network, you may need a Switch (Much better than a HUB) then plug up the cables you are going to use to the switch.
I have had a network running at home for about 10 years now (6PC's and a server)
It used to run with a Dial up modem and it autodialed on demand, and dropped out after a fixed "no-traffic" period.
I used a simple PC running Smoothwall for that, and it worked a treat.
http://www.smoothwall.org/
Just need an old PC of 50mhz or better and a modem. It also now works with a WAN connection from a straight ADSL modem, or USB modem. Excellent software... and free too!
Mind you, most people get a free ADSL router witha 4 port hub from their ISP as part of the deal.
So stick to Cat6 Cable (Cat5E as a minimum).
Put 2 cables in to every location (even if you just hide the spare in the back of the box). Leave at least 200mm cable to be able to strip back and terminate properly. No Bow String tensioned wiring. It becomes unreliable and will give problems.
Believe me, I've been in the Phone Business for 40 years.
Best Regards
Geoff
http://www.v8viento.co.uk
wilkingj
posted on 1/11/09 at 11:23 AM Reply With Quote
Why not just terminate the cables with RJ45 plugs and plug straight into the Hub or Switch? Agreed a Patch Panel is neater and more professional.
Oh and dont forget to Label the cables as you put them in. So much easier when coming to sort it out later
You could just do RJ45 plugs on each end of the cables and then save some money that you would spend on sockets and back plates and a panel.
Final word. Its worth buying the correct Ratchet Crimping Pliers for the RJ45 plugs for the same reasons you would buy the ratchet crimpers for the lucar connectors on your Kit car!
I wouldn't buy the kit from Screwfix. (2 cables to 2 rooms for £35!)
Go to somewhere sensible (Leccy or Comms wholesaler) and buy a 100m (305ft) box of Cat 6 cable, and then a pair of crimpers and a bag of plugs (I got crimps etc from Maplin).
You can do the entire house with some quality cable and still have some spares.
[Edited on 1/11/2009 by wilkingj]
Best Regards
Geoff
<<  1    2  >>
